Ecu question here..
Old Aug 18, 2015 | 09:26 AM
EJ8CIVIC's Avatar
Default Ecu question here..
96 integra Ls w/b16a2
Currently running p75.. Which be the best ecu to get? P28? Or what
And i know for which ecu i need to wire in vtec..
I have a jdm p73 ecu, from what i read itll dump to much fuel ad vtec kicks in at 4400rpm
Old Aug 18, 2015 | 10:05 AM
B_Swapped93's Avatar
Default Re: Ecu question here..
a P2T is the correct ecu regardless you need to run the wires for vtec rywire sells them for like $40 or so it easy just takes a bit of time.
the cross over would be different along with the rev limit that's why you stick to the correct ECU unless you go with some aftermarket EMS like a s300.
Old Aug 18, 2015 | 11:16 AM
EJ8CIVIC's Avatar
I believe i have a p2t ecu that came with the motor..This harness?
http://www.rywire.com/mobile/Product.aspx?id=37913
Old Aug 18, 2015 | 12:50 PM
that's the correct ecu.. and yes that harness.
Old Aug 18, 2015 | 01:47 PM
EJ8CIVIC's Avatar
Cool thanks
J_Barajas
Aug 19, 2017 12:21 PM
93slmdcvcsi
Feb 15, 2006 02:44 PM
