IAT sensor has been a pain
Old 06-28-2015, 04:02 PM
Dynasty21's Avatar
Location: Where We Squeeze 1st N Ask Questions Last, CA, USA
Default IAT sensor has been a pain
Fresh motor with turbo tuned s300
OBD2B GSR harness into ITR motor
New IAT, check voltage and there's about 5v on signal wire, and ground is good. If there is power and good ground on it then leads me to believe there is good connection on the harness. I unplugged the battery overnight and still CEL came on for IAT. IACV is on too but that's not a problem. I tried all 3 plugs that are the same, maybe I got them mixed up, but CEL didn't go away.
Old 06-28-2015, 05:46 PM
wunfstgsr's Avatar
Default Re: IAT sensor has been a pain
Confirm which is the correct plug, look up what color the wires should be. Clear the code with a obd2 scanner and see what happens.
Old 06-29-2015, 02:39 AM
Technical Hero
HondaPartsHero's Avatar
Post pics of your connectors and we can ID them. Also its possible to fry IAT's if you plug in the wrong sensor as it will send too much voltage through the sensor.
Old 07-03-2015, 01:57 PM
Dynasty21's Avatar
Ok, I tried clearing the code but since my ecu is obd1 with s300, the scanner can not communicate with ecu.
I'll have to check the wires and make sure which is which, I tested the one I have on now and there is a little less than 5v and there is ground.
Dynasty21
06-28-2015 05:24 PM
luispequeno
12-13-2010 09:16 AM
Rease3
07-14-2009 12:46 PM
king_pin
03-27-2009 06:43 PM
fryguy190
11-11-2008 10:22 AM
Quick Reply: IAT sensor has been a pain
