B20B identicfication...
Old Sep 1, 2015 | 04:41 PM
MountSolonDA's Avatar
Default B20B identicfication...
I bought this from a local importer and was told it was a B20B 9.2:1 compression motor. When i looked up the date codes and head number though i cant decypher it. the four circles above exhaust manifold that should be date codes are 66 09 10 7. The 9 is clearly marked with a under line to show its a 9 and not a 6. The head is a P75-2. Can any one tell me what year, compression ratio, and possibly even what it came out of? Thanks in advance for the help.
Old Sep 1, 2015 | 04:45 PM
B_Swapped93's Avatar
Default Re: B20B identicfication...
do you have a knock sensor? if not it's the "lower" compression if yes it's the "higher" compression. generally the 9:6.1 is the most expensive so I hope you paid for what you got
Old Sep 1, 2015 | 08:14 PM
Andrew7447's Avatar
if not just throw more boost at it lol.
Old Sep 1, 2015 | 08:57 PM
tony_2018's Avatar
Fish Twig
If not just throw nos at it HAHAHA
Old Sep 2, 2015 | 03:22 AM
blackeg's Avatar
you can also check the intake cam to see if its a p75 making it a "high" compression but as said usually looking for the knock sensor is the quick way to do it.
Old Sep 2, 2015 | 06:43 AM
It does have the knock sensor in back of the block, and the head is a p75-2, paid $450 for it, but i was wondering if its a 9.2:1 or 9.6:1 ratio, tried looking it according to those block stamps... thats where i got lost at. Kinda new to the honda/Acura scene got this in febuary for mpgs cause i built my titans motor and get about 13mpg average. This will be my first swap, the guy before me screwed up about everything on the motor and suspention, I put function form type 2s on it, brand new bushings, ball joints, everything under the car is new as when i got it all was ruined. So i figured id put a new motor in, b20 has 60k miles, competion clutch and lightweight flywheel, and aluminum radiator. Have all those parts for the swap now but i work 7 days a week so im waiting on a time to do it.
Old Sep 3, 2015 | 08:34 AM
blackeg's Avatar
should be 9.6:1. they are still quite close together and almost negligible
slow_low_eddie
Jun 14, 2014 11:53 AM
ThatSlowKid
Honda CR-V & Element
15
Apr 11, 2014 04:21 AM
felipe69
Apr 1, 2009 06:10 PM
OOOtony
Northern California (Sales)
12
Feb 12, 2009 08:31 PM
98vtec
Apr 3, 2007 05:51 PM
