Alignment?
Old Jun 14, 2015 | 06:26 PM
1990IntegraLS's Avatar
Icon2 Alignment?
I want to change all bushing and other rubber parts in all my suspension.
I've done some reading on bushings and have decided to get the OEM bushings. What I can't find is, will I need an alignment after changing these parts?
Thanks!
Old Jun 14, 2015 | 06:55 PM
MotorMouth93's Avatar
10 Year Member
Default Re: Alignment?
Whether or not you need one is debatable (assuming you mark the settings of the adjustment points before you loosen anything), but it's a good idea to get one. It's not that expensive and you can potentially save yourself some unnecessary tire wear.
Old Jun 14, 2015 | 07:17 PM
The problem is where to get an alignment. Where I'm probably going to do the work is out in the middle of nowhere...little town I work in, and I wouldn't trust ANY mechanic of any sort within 2-3 hundred miles.
Even in San Antonio, who do I trust to do a good job?
Last time I trusted someone else to do any work on one of my vehicles, was just a dumb tire fix, and they broke an aluminum wheel on my F350....with an impactor.
Old Jun 15, 2015 | 10:21 AM
tamboo's Avatar
10 Year Member
fwiw:
San Antonio » Automotive » Wheel & Rim Repair - Yelp
Old Jun 15, 2015 | 12:42 PM
Originally Posted by tamboo
Do they do alignments?
...or are you suggesting something for the rim I lost. I would never repair a rim, especially on a 1 ton dually with a 7.3L, that from time to time pulls 5 tons. I wouldn't even use a repaired rim on my Teg. I bought 2 news ones for the front.
Old Jun 15, 2015 | 05:03 PM
Some of these take more then one....maybe some of the hard part too, depending on what I find.
RUBBER, STABILIZER END
BUSH, FR. RADIUS ROD (RR)
BUSH, FR. RADIUS ROD (FR)
BUSH, SHOCK ABSORBER
BUSH, FR. ARM (LOWER)
BOOT, BALL DUST (LOWER) (MUSASHI)
BUSH, STABILIZER END
BUSH, STABILIZER LINKAGE
COLLAR, STABILIZER BUSH END (INNER)
BOOT, TIE ROD END (TECHNICAL AUTO PARTS)
DUST SEAL, TIE ROD
CUSHION B, POWER STEERING RACK
END, L. TIE ROD
END, R. TIE ROD
BUSH, FR. ARM (UPPER)
BUSH, RR. SHOCK ABSORBER (LOWER) (YAMASHITA)
BUSH, RR. ARM (UPPER) (YUSA)
BUSH, ARM (UPPER) (INNER) (YUSA)
BUSH, RR. ARM (LOWER) (HOKUSHIN)
BUSH, COMPENSATOR (YAMASHITA)
ARM, RR. COMPENSATOR
D16SohcVtec
Suspension & Brakes
Apr 3, 2009 08:04 AM
sleepinEP3
Mar 26, 2008 12:28 PM
AJ21GSR
Sep 5, 2005 04:55 PM
95greenlude
Jul 25, 2005 04:00 PM
badnan
May 29, 2002 12:21 PM
