Trans problems, stumped
Old Jul 2, 2015 | 03:36 PM
mikeybee95's Avatar
Default Trans problems, stumped
I just finished doing a full gsr swap into my ek, the problem is I can shift into 1st, 2nd, 5th and reverse fine, but 3rd and 4th are just not there. It's like hitting a wall. I had the trans apart prior to putting it in and everything seemed fine. Any idea?
Old Jul 4, 2015 | 06:18 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: Trans problems, stumped
You said EVERYTHING looked fine! did you or another person inspect the internals?
And did these issues happen after you inspected the trans or did you have the same problem before you inspected it?
you have either bad sleaves or your shift fork may be bent and or other internal problems id rule out the clutch at this point.
Old Jul 5, 2015 | 10:24 AM
IN VTEC's Avatar
Does it go into the 3-4 gate with the engine off?
Old Jul 6, 2015 | 10:16 AM
mikeybee95's Avatar
I had originally purchased the trans together but needing a main shaft bearing, I did the bearing and since then had problems with shifting. Benching shifting I could get through all the gears, then one day it wouldn't shift at all. (Figured the pin for the assembly has popped out, and it did) so I resplit the case and put the pin back in, then it wouldn't shift into 1st or 2nd, split it again and got it to shift, but then when I put it back in, it wouldn't shift again. But no it won't shift with the car off either
Old Jul 6, 2015 | 06:06 PM
fcm's Avatar
fcm
Old Fart
Mis-assembled, or bent shift fork, as mentioned.94
Old Jul 11, 2015 | 04:51 AM
oldschoolmaster's Avatar
Sounds like you bent something should have paid me to do it right the first time lol
Old Jul 11, 2015 | 04:54 AM
ferio-ichi3's Avatar
Ferio Wdm Edition
How were the synchro springs? When i first got my trans, it had no 3rd gear due to the synchro spring being completely broken. You say its like hittig a wall. If you try pushing harder, does it grind?
cfahamilton
12
May 10, 2017 06:03 AM
matcat86
Transmission & Drivetrain
13
Jul 18, 2014 09:46 AM
stevenDAtegra
12
May 3, 2010 10:57 PM
FIxALPHA
Sep 10, 2003 04:47 PM
mike2016
May 20, 2001 03:03 AM
