OBD1 Intake Manifold Problem
Old Aug 31, 2015 | 08:42 PM
Virgle DeBord's Avatar
Default OBD1 Intake Manifold Problem
So I installed the obd1 manifold and I'm having a coolant issue. Which line did I not run right? Motor overheats real fast. Thank you for the help. If you would be so kind please text 916 425 1620 with advice this is a rather critical problem in my life.
Old Aug 31, 2015 | 08:59 PM
theYBLEGAL's Avatar
Loved
Default Re: OBD1 Intake Manifold Problem
Bleed the coolant? No air?
Old Aug 31, 2015 | 09:10 PM
Make sure there's no air? is that what you mean? I need you to text me bro 916 425 1620 i literally have been told like 5 different ways of doing this right its on a obd2 99 b20b with all obd1 except for this which is why im doing a obd1 intake manifold, just that theres two less lines on obd1 and i cant get the car cooled off now
Old Aug 31, 2015 | 09:13 PM
Small coolant line off the motor is still plugged into the valve on the tb correct? tb to iacv? Well I've got a open line off the thermostat right now that's plugged is that right?
Old Aug 31, 2015 | 09:14 PM
So just bleed the coolant or BURP it yes?
Old Aug 31, 2015 | 09:35 PM
theYBLEGAL's Avatar
Loved
Car cold, remove rad cap. Start motor. As coolant level drops/air leaves, add coolant to rad. Until fan kicks on. Then replace cap, and make sure overflow is within range. Done.
Do not open a radiator cap if system is hot. You can severly burn yourself.
Old Sep 7, 2015 | 10:36 PM
Do dragons drive cars? Yeah I know about radiator caps. What I have to do now is replace a thermostat and a wiring harness. Thanks.
PatrickGSR94
Nov 27, 2008 04:32 PM
redDAinteg
Dec 27, 2007 05:52 AM
dunkd
Mar 28, 2005 09:04 PM
typeeg
Jul 10, 2004 02:54 PM
