Breaking Down- Integra
Old Jun 23, 2015 | 07:06 AM
gsr17y's Avatar
Icon6 Breaking Down- Integra
00 Integra GSR B18C1
128k Miles
No CEL
Starting a couple weeks ago.. my car will start up and drive no problem, out of no where the engine will just die (doesnt matter if im stopped or moving) 20 seconds of sitting there and it will start back up and drive fine. (This would happen usually about once in my point A to point B commute) Now.. as of this moring on my way to work (3.5 miles away) i got to the top of my road and engine dies, this time it did not want to start after 20 seconds, the car was turning over fine and after trying in intervals for about 7 minutes it started. I still took my gamble to try to get to work in it and it happened 3 more times with not wanting to start back up. Luckily I was able to get it back home though. When the engine dies the battery and other lights come right up on the cluster. As of today this problem has gotten worse and i do not feel comfortble driving it anywhere.
What are ya'll thoughts?
Old Jun 23, 2015 | 07:34 AM
MotorMouth93's Avatar
10 Year Member
Default Re: Breaking Down- Integra
My first guess would be something in the distributor. Start by testing the ICM and coil.
Old Jun 23, 2015 | 07:48 AM
JustDo1nMe's Avatar
Im the OP this is ganna be my actual account, ok how exactly do I test those?
Old Jun 23, 2015 | 08:32 AM
rallyrcr's Avatar
Any check CELs on your dash?
Old Jun 23, 2015 | 09:07 AM
JustDo1nMe's Avatar
No check engine light
Old Jun 23, 2015 | 01:04 PM
KiNGDEE206's Avatar
Sounds like your dizzy. Have someone check out ur dizzy like the above suggestion. Dizzys are common to go out on our hoondas
Reason why it starts up after xx time is because the dizzy cooled down thus having contact again. When it's too hot it loses connection
Old Jun 23, 2015 | 02:46 PM
tamboo's Avatar
10 Year Member
Advanced Ignition Troubleshooting - Team Integra Forums - Team Integra
Starting Problems
Old Jun 23, 2015 | 03:01 PM
JustDo1nMe's Avatar
Thanks for input
Old Jun 24, 2015 | 07:07 AM
JustDo1nMe's Avatar
Im ordering a RichPorter dizzy today. Hopefully this solves my issue.
Old Jun 24, 2015 | 12:41 PM
wunfstgsr's Avatar
Loved
Community Favorite
I had a similar issue it was neither the ICM or coil, Best to check both those sensors to confirm, i believe theres another magnetic sensor in the distributor that fails. I too ordered a rich porter distributor and it works great.
Old Jun 25, 2015 | 07:09 AM
JustDo1nMe's Avatar
Thanks for feedback, I should be getting mine today ill update once installed
Psykomantis00
11
Feb 25, 2014 04:52 AM
explosive
Aug 21, 2009 04:30 AM
zoso
13
Jun 24, 2009 05:39 PM
djwest24
Oct 24, 2005 07:44 PM
