ECT Sensor or Sending Unit?
Old Jul 25, 2015 | 08:42 PM
daboy155's Avatar
Default ECT Sensor or Sending Unit?
1998 Integra LS, My temp readings are very inaccurate. I have hondata s300, the temps always hang or freeze at 194.7 and 196, I used to plug into the OBD2 port before I got hondata and they would always be 196 also so I know it's not hondata.
The car is for sure over heating(I need a new radiator since my current one is junk aftermarket the previous owner put in and the turbo is heating the coolant up too much)
Sometimes it will randomly update and the coolant will show 227(at the very highest), or 212, but it just sticks and jumps around a lot, makes it hard to know what it's really at. The needle never moves past half either. Do I need to replace the Sensor or the Gauge Sending unit? I know they are both near the oil cap on the head.
Old Jul 25, 2015 | 09:32 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: ECT Sensor or Sending Unit?
do your fans come on?
if so its most likely the sending unit sensor.
Id first replace the radiator then go from there.
Old Jul 26, 2015 | 07:11 AM
daboy155's Avatar
They do come on very very quickly and stay on for a very long time. I'm going to replace the radiator and see if that helps at least, just wish I could monitor the temps more accurately. I'll look into the sending unit sensor.
Old Jul 30, 2015 | 09:36 PM
daboy155's Avatar
Radiator replaced today,coolant bled, spal fan added, temps staying lower and don't seem to be overheating at idle, but won't know for sure until i take it out on the road. The readings are still screwy though, they like to stick at 194 and 196, I can tell the car is running a bit hotter than that. (before the new radiator/fans it was just stuck at 194 and I knew it was getting hot, then it would jump to like 212 once the sensor registered)
I can get a decent Sender Switch with Gauge for less than 20 bucks, that the first thing I should try?
Old Aug 1, 2015 | 11:51 AM
wunfstgsr's Avatar
Loved
Community Favorite
Try a new oem ECT sending unit sensor.
Old Aug 1, 2015 | 12:02 PM
daboy155's Avatar
is that this one that sits on the side of the thermostat neck area
Radiator Fan Switch - 1AZMX00041 at 1A Auto.com
Old Aug 1, 2015 | 12:29 PM
wunfstgsr's Avatar
Loved
Community Favorite
No thats the fan switch.
LikeThis one, OEM is best though.
http://www.ebay.com/itm/Water-Temperature-Sender-Sending-Unit-Sensor-for-vehicles-with-gauge-/190539220872?hash=item2c5d05c788&vxp=mtr
Billy Baird
Dec 27, 2012 10:32 AM
Spawne32
Apr 17, 2011 03:55 PM
TegraGSXR
May 29, 2010 11:37 AM
2000_Civic_Si
Apr 3, 2002 09:03 AM
