heater bypass- temp gauge bounces from c to normal
Old 07-15-2015, 10:06 AM
tamboo's Avatar
Default heater bypass- temp gauge bounces from c to normal
i farked the heater core connections to get out rear motor mount so i disconnected the passenger side heater hose from the heat switch and plugged it into the engine where the other hose goes. now i cant seem to get all the air out. jacked front up as high as possible,
kept fluid topped off. opened nipple with cap on and off. doesnt seem to be any more air coming out. temp gauge is mostly on c but will move up to norm sometimes. everything worked fine before this . wtf?!?
Old 07-15-2015, 01:53 PM
tamboo's Avatar
Default Re: heater bypass- temp gauge bounces from c to normal
never mind, loose connection at temp sensor.
today it would just sit at c unless i made a right turn at 40 or over
which then completed the connection temporarily lol.
must have knocked it loose while i was pulling upper trans mount
for window weld job. seemed to be getting better mpg while
this issue was going on too, weird.
Kalen13
Honda CR-V & Element
01-18-2018 11:04 AM
deerman2701
23
12-10-2012 05:36 PM
kornerk12
07-15-2008 04:59 PM
Mikey
01-08-2005 08:03 AM
Ti3d in
08-04-2004 06:38 PM
Quick Reply: heater bypass- temp gauge bounces from c to normal
