Defi EGT Guage Sensor Install Location?
where should I install it on a inline pro manifold like the one pictures above?
I was thinking either #1 cylinder or between WG and turbo from the radiator side.
Thanks
Re: Defi EGT Guage Sensor Install Location? (B18Flip)
I'm pretty sure most people say to use the #3 runner
Re: Defi EGT Guage Sensor Install Location? (boostedb20vtec)
My used 4 bolt ex housing came with two holes tapped in it. This is JDM style. All of my RX-7 and Skyline buddies run the same setup.
Re: Defi EGT Guage Sensor Install Location? (Dee)
Re: Defi EGT Guage Sensor Install Location? (B18EG6)
I didnt tap my mani...I used the hole for an internal wastegate on the downpipe...want a pic of that?
1 Post
Re: Defi EGT Guage Sensor Install Location? (integra-modder)
Do it on the Manifold 3rd runner about 1inch to inch and half away from the flange. Also good idea to mount the WG so you have a good idea how much area the Sensor sill need. You might tap to close to the WG.
1 Post
Third runner is the runner second from the left. and i say 1.5inches from the block or the flange from the block is fine.
