squealing noise during boost?????
Old Mar 3, 2003 | 02:07 PM
asianspeed's Avatar
Default squealing noise during boost?????
I just started boosting today, but when I get under boost, I heard a loud squealing noise from about 3 psi - 8 psi. Any idea's what would cause this? Will it go away after using it for a while....I did just put it in, could that be it?
Oh, by the way, this is a used 14b turbo that had about 80k miles on it.
Old Mar 3, 2003 | 02:38 PM
Diego Boost's Avatar
Default Re: squealing noise during boost????? (asianspeed)
You sure it's not your turbo spooling? It may be the bearings/bushings (niot sure what comes in those turbos) are bad/going bad .
[Modified by Diego Boost, 11:39 PM 3/3/2003]
Old Mar 3, 2003 | 03:16 PM
madman604's Avatar
could it be your belts?
Old Mar 3, 2003 | 03:25 PM
ninesecrx's Avatar
if its not the noise of it spooling, it might be the blades hitting the housing making a metalish squel noise.
Old Mar 3, 2003 | 03:40 PM
ion_four's Avatar
Default Re: squealing noise during boost????? (ninesecrx)
haha, I think that noise would go away really quickly...with your turbo
Old Mar 3, 2003 | 03:46 PM
liam821's Avatar
25 Year Member
the only squeling noise i ever heard boosting was my tires...hehe But the t25/14b is very loud..it makes ALOT of noise. Could you make a wav for us?
liam
Old Mar 3, 2003 | 04:01 PM
BoostedGSRBubble's Avatar
Default Re: squealing noise during boost????? (liam821)
I just started boosting today too (sorta). Im only runnig a downpipe now and i can hear my turbo spool nice.
Old Mar 3, 2003 | 11:31 PM
asianspeed's Avatar
Default Re: squealing noise during boost????? (BoostedGSRBubble)
What does your turbo spooling sound like?
Old Mar 4, 2003 | 04:57 AM
Tinker219's Avatar
like a pissed-off jet, combined with the sound of a screaming newborn, all on top of an engine note that quadrooples in speed because of the newfound air....
Old Mar 4, 2003 | 05:36 AM
Drag_On's Avatar
Default Re: squealing noise during boost????? (Tinker219)
Sounds to me like your wastegate is bleeding off boost and sqeualing..
I had that same problem.. What BOV are you running ? If your running a factory unit-- that would for surely be it.. If its aftermarket-- that still could be it..
Check your BOV for leaks.. I'll put money on it.. I know the sound you describe..
Old Mar 4, 2003 | 06:53 AM
NinjaBuc's Avatar
Default Re: squealing noise during boost????? (Drag_On)
Not sure if it will apply here, but on my old Supra this was usually caused by a leaky manifold. Supra owners called it the "Screaming Banshee" mod. Might be worth a quick check. I think what caused the noise was all that boosted air trying to squeese through a small space and whistling, thats why you don't hear it out of boost.
Josh
boostedd16z6
Dec 26, 2007 03:05 PM
teddy_dc2
May 25, 2006 11:39 AM
Damion W
Jun 28, 2005 08:54 PM
hawjboi
Jun 28, 2002 07:43 PM
