Will a P72 ecu run my H23..
well i got the hondata ready to go... just wanna make sure the ecu i bough works.. if it will should i plug in the hondata..
Re: Will a P72 ecu run my H23.. (MordecaiPSI)
will it idle and **** or will i have to install it in a parkin lot at the tuners place
Re: Will a P72 ecu run my H23.. (BoostedH23a1)
if you dont chip it with h23 fuel maps, it will idle like **** cuz its running too lean (approx 21% lean). If you dont want to chip it, force your car into limp mode, that will give you enuf fuel to drive around.
