Oil dip stick
Old Mar 1, 2003 | 09:16 AM
gsrhunny's Avatar
Default Oil dip stick
I have a Greddy kit on my GSR, my question is what can I do bout the oil dip stick? The little rubber part that seals it keeps melting. Thank you.
Old Mar 1, 2003 | 09:18 AM
B20-T's Avatar
Default Re: Oil dip stick (gsrhunny)
trim it
Old Mar 1, 2003 | 09:34 AM
boostedsol's Avatar
Default Re: Oil dip stick (B20-T)
trim it
Old Mar 1, 2003 | 09:35 AM
gsrhunny's Avatar
Trimming it isnt gonna do anything, it's still gonna melt and won't seal. Thanks anyways.
Old Mar 1, 2003 | 10:25 AM
DeepSi's Avatar
have you tried to push the oil dip stick tube some. Bend it a little bit?
Old Mar 1, 2003 | 11:04 AM
AlphaKennyWun's Avatar
Default Re: Oil dip stick (DeepSi)
Buy a new dipstick and bend the metal neck piece so that nothing is touching the turbo manifold or anything else.
Old Mar 1, 2003 | 11:25 AM
FredoSP's Avatar
HAhahaha Same with me ... u can do two things.
1. Get a new one every 6 months
OR
2. go to http://www.jcwhitney.com and get this, one guy uses it from here and says no more melting .. .let me know.
http://www.jcwhitney.com/product.jht...D=410609&BQ=sc
- Fred
Old Mar 1, 2003 | 11:38 AM
Kwuaymaikrup's Avatar
Wrap it with a small amount of header wrap. Works perfectly and you don't have to wait for it to cool before you grab it. Good luck.
-Ryan
Old Mar 1, 2003 | 11:44 AM
boostedsol's Avatar
Maybe in your situation that is the case, but w/ mine, all I did was trim/bend and I have no melting or fitment issues anymore.
Gl though.
Old Mar 1, 2003 | 07:57 PM
gsrhunny's Avatar
Default Re: Oil dip stick (boostedsol)
Thanks FredoSP, im gonna check it out. As for the suggestion to trim and bend doesn't help with the piece that melts which is the green rubber that seals the hole where the dip stick goes (no seal...oil spits out and gets on hot engine and car starts smoking), but thanks anyways.... .
Old Dec 7, 2003 | 03:01 PM
integra-modder's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrhunny &raquo;</TD></TR><TR><TD CLASS="quote">Thanks FredoSP, im gonna check it out. As for the suggestion to trim and bend doesn't help with the piece that melts which is the green rubber that seals the hole where the dip stick goes (no seal...oil spits out and gets on hot engine and car starts smoking), but thanks anyways.... .</TD></TR></TABLE>
I have the same problem.....and this happened half way on the drive down to school. I had to drive 40 mph for 100 miles...
Old Dec 7, 2003 | 11:23 PM
boostedsol's Avatar
well the exact same thing happened to my friend with a greddy kit. everytime he boosted his car would smoke like crazy.... he wraped some heater wrap around it and now it works fine.
Old Dec 8, 2003 | 04:17 AM
_jester_'s Avatar
I bought the STR dipstick, its metal, and the rubber grommets are in the tube, i had a greddy kit as well-
Old Dec 10, 2003 | 08:31 AM
Default Re: Oil dip stick (XratedSi)
any problems of the orings potentially melting themselves to the dip stick tube?
Old Dec 14, 2003 | 07:17 AM
_jester_'s Avatar
Default Re: Oil dip stick (integra-modder)
No, but i had slid a piece of the heatwrap over my oil tube-
Old Dec 14, 2003 | 03:55 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XratedSi &raquo;</TD></TR><TR><TD CLASS="quote">No, but i had slid a piece of the heatwrap over my oil tube-</TD></TR></TABLE>
what type of heat wrap was this? was it regular exhuast heat wrap?
pjr710
18
Jun 8, 2008 09:09 PM
EFinSi
Feb 12, 2008 08:20 AM
vu337
Dec 28, 2003 08:34 PM
94dxt
Apr 3, 2003 10:53 PM
MooreBoost
Jan 8, 2003 05:23 AM
