all those w/maxrev BOV
Old Feb 28, 2003 | 05:11 PM
dirtySOHC's's Avatar
Default all those w/maxrev BOV
so i was test fitting everything yesterday on my car, i cut and cut and cut and assembled until i got the perfect fit.......i was like wow cant wait to get this thing on the road.
i took everything apart and headed down to the local welding shop to get the BOV welded on and to my disappointment i was told they wont be able to do it. they told that they cant weld the maxrev BOV aluminum flange to steel piping.
i not knowing jack **** about welding didnt know this. so wat i am asking is for all those that are running this BOV where did you get aluminum piping or wat is your method of gettting the damn thing on.......??
help a boost hungry fellow out.
Old Feb 28, 2003 | 06:43 PM
redline201's Avatar
Default Re: all those w/maxrev BOV (dirtySOHC's)
ttt
id like to know also
i have the max rev bov and the stainless steel DIY piping
Old Feb 28, 2003 | 06:52 PM
20lb.teg's Avatar
Default Re: all those w/maxrev BOV (redline201)
Get somebody to make you a steel flange, or buy one... trust me it will be A LOT less headache. First if you find anyone that can weld Al then it will usually be a little more in price, second finding Al piping to make a charge pipe is not going to be easy if at all possible. Hope this helps
Later,
Sean C.
[Modified by 20lb.teg, 3:52 AM 3/1/2003]
Old Feb 28, 2003 | 07:16 PM
Smashback's Avatar
This has been covered a million times...in fact, I asked it like a year and a half ago.
Anyway, that's strange that they are including al. flanges when nobody uses aluminum piping...
Old Feb 28, 2003 | 08:01 PM
rOby's Avatar
Default Re: all those w/maxrev BOV (Hatchblack)
i suggest u get some sort of steel adapter made..kinda like a flange for the fitting or flange. damnt i cant type what i mean. you know how the wg on sfp manis have the elbows? get somethin like that welded and bolt ur wg to that ...
Old Feb 28, 2003 | 08:21 PM
RyanAutry's Avatar
Except Honda-Tech's Search fucntion sucks....
This is all I found about Max Rev's BOV
https://honda-tech.com/zerothread?id=418867
Old Feb 28, 2003 | 09:13 PM
Pat's Avatar
Pat
Default Re: all those w/maxrev BOV (RyanAutry)
anyone try using a steel Greddy flange? I read before that the maxrev bov fits on blitz/greddy mounts.
I also want to know why they included an aluminum flange with steel piping...
Old Feb 28, 2003 | 10:56 PM
CzanSOHC's Avatar
Default Re: all those w/maxrev BOV (Pat)
I called Max Rev becuase they forgot my flange...they said they they started making AL flangrs instead of steel becuase for some reason..i forget...anyway...they are now starting to run steel flanges again...give them a call and tell them your problem.
Old Mar 1, 2003 | 07:06 AM
hondaswaper's Avatar
Default Re: all those w/maxrev BOV (CzanSOHC)
we mounted it on the Intercooler in a car we just put a max rev kit on....
Old Mar 1, 2003 | 01:46 PM
sounds good man.....calling them now
thanks for the replies guys i didnt know if would get any.
Old Mar 1, 2003 | 01:55 PM
just got off the phone with Kyle and he says that the steel flanges will be done in about 2 weeks or so. He says that they already have the design and they just gotta get them made.
Old Mar 1, 2003 | 04:57 PM
krazy's Avatar
heres a quick fix that works:
get a aluminum pipe the same size as urs, weld on the flange, and use hose clamps to connect to your steel piping. this should work, but its not that pretty.
do u guys know if the steel flange is in the ne maxrev kits? i just ordered a kit just a few days ago.
krazy
Old Mar 1, 2003 | 05:12 PM
r7's Avatar
r7
Default Re: all those w/maxrev BOV (krazy)
how about my aem cai? is it alum. ? i think i'm just going to use that as charge pipe, where should i locate the bov on that pipe?
Old Mar 1, 2003 | 05:46 PM
krazy's Avatar
Default Re: all those w/maxrev BOV (r7)
yea that should work. location is personal preference, some like it half way, some like it all the way to the top by the t-body. all up to u. i dunno which is ideal though, id think some where between the t-body and halfway is good.
krazy
Old Mar 1, 2003 | 06:01 PM
Default Re: all those w/maxrev BOV (BillyBob)
hmm that is weird...i talked to kyle just recently and here's what he told me
hey kyle
any further word on the BOV flanges? im installing everything next week during my spring break........
(5:18 PM 2/27/2003) 2K_TEG: they have been shipped. I will confirm tomorrow.
2 weeks??? i hope not, or else i am not going to be happy
[Modified by BillyBob, 1:55 AM 3/2/2003]
was this the aluminum flange?
krazy
my problem is finding aluminum piping, if you know where to get it please let me know.
Old Mar 1, 2003 | 07:15 PM
krazy's Avatar
heres somethign im gonna try. on EBAY theres a lot of generic CAI selling for like 45 bucks with a filter. id get one like this and hack it up for the BOV flange, and the remainder piping id make a filter for the turbo. since the maxrev doesnt come with one. remember though, some of those intake pipes are 2.5 inches and 3 inches. make sure to get the one u want. the maxrev pipes are 2.25 inch. i maybe u have to use the intake pipe as the charge pipe.
krazy
Old Mar 1, 2003 | 07:56 PM
krazy
^something i dont wanna do. ill just be patient and wait for kyle to let me know when the steel flanges are done.
Old Mar 1, 2003 | 10:18 PM
CzanSOHC's Avatar
hmm....max rev tolds me it was only going to be a couple of days to run them through the CNC.
Old Mar 1, 2003 | 10:26 PM
redline201's Avatar
has anyone used the aem cold air intake as a charge pipe?
my max rev piping is 2.25 and my aem is 2.5
will this be a problem
i might a steel flange from a greddy (im pretty sure it fits the mav rev bov)
is using a cold ar intake for a charge pipe ghetto??
or does it perform just as well as a steel charge pipe
thanks
Old Mar 1, 2003 | 10:31 PM
CzanSOHC's Avatar
thanks
you can use the CAI for a charge pipe.
As far as the GReddy and max rev sharing the same flange....wrong..the design is the same but the MAx rev BOV and flange is slightly smaller..you can get it to work but you have to redrill the holes in the flange to make it work correct...i did and it looks like ***...so i called max rev and i should be getting a nex flange in the near future.
Old Mar 1, 2003 | 11:05 PM
redline201's Avatar
thanks for correcting me
Old Mar 2, 2003 | 01:06 AM
krazy's Avatar
hopefully my kit has the steel flange. and ill just hack up my regular intake for the turbo intake. anyway if u find any other way around it let us know. i have no idea what aluminum flanges would be for... maybe for supercharger bovs?
krazy
Old Mar 2, 2003 | 11:15 AM
01ITR#700's Avatar
I tried getting an answer to this too about a week ago. It boggled me that they would sell steel DIY pipes and send an alluminum BOV flange. SO will they swap out the alum. flange with steel flange for free? I hope so.
M
Old Mar 2, 2003 | 02:21 PM
krazy's Avatar
its really not kyles fault, more like maxrevs. u should call maxrev and tell them. kyle is just the distributor. the turbo kits get sent out from maxrevs location.
krazy
D15B_Turbo
Sep 14, 2003 08:51 PM
adhana2
Jun 2, 2003 02:16 PM
curiousgpnoy
Jul 18, 2002 11:09 AM
lsvtec101
Jun 15, 2002 09:40 PM
TurboSedan
Oct 20, 2001 12:34 AM
