Downpipe material needed?
Old Feb 28, 2003 | 03:46 PM
420aNT's Avatar
Default Downpipe material needed?
Were can I get 3inch mandrel bent piping to build my downpipe. I have looked all over and to no success. Also why is the exhaust hole on the 5 bolt flange that bolts onto my turbo smaller than the outlet on my Turbo. I need a flange with a hole at least the same size as my turbo.
Old Feb 28, 2003 | 03:53 PM
DSC's Avatar
DSC
Default Re: Downpipe material needed? (18gTeg)
JC Whitney sells mandrel bent piping.
Old Feb 28, 2003 | 04:00 PM
420aNT's Avatar
not in 3" stainless!!!!
Old Feb 28, 2003 | 04:19 PM
DSC's Avatar
DSC
Old Feb 28, 2003 | 04:20 PM
420aNT's Avatar
Default Re: Downpipe material needed? (DSC)
Yeah I know. I have been looking like crazy but with no luck. Someone out there has to know a place that carries it.
Old Feb 28, 2003 | 05:35 PM
420aNT's Avatar
ttt
Old Feb 28, 2003 | 05:45 PM
tSuperbike69's Avatar
http://www.burnsstainless.com
Old Feb 28, 2003 | 06:01 PM
420aNT's Avatar
Default Re: Downpipe material needed? (tSuperbike69)
Is there any were else that has more of a selection and cheaper prices? There stuff is crazy high priced for low end stainless piping. I need a really tight radius bend for my setup. I am not seeing anything this tight on there site. I built my first DP with regular aluminized piping. I used a 180 degree bend off my turbo but it hangs about 2 inches lower than my front lip. The one I used had about a 7.5 inches between the two legs off the bend. I need one with around 5-6 inches in between. What size downpipe is everyone else running. I already have a full 3" exhaust as is, so I figured I would go with 3" for the downpipe as well. But the way it looks I might not be able to do it and make it look nice.
Old Feb 28, 2003 | 06:20 PM
420aNT's Avatar
Okay so I found a place that carries 3" U bends in stainless. The question I now have is about the radius. The site says that the pipes legs are 6" long and the radius is 6inches. So what is the distance between the two legs? I can only have 6" at the most on my setup or it will drag the ground. Can someone please help me here?
Old Feb 28, 2003 | 06:28 PM
b16ahybrid's Avatar
Radius = the distance from a center line or point to an axis of rotation. or 1/2 the diameter.
so the distance is 12'' from leg to let. You can cut the u-bend and use the necessary pieces. you can make that a shorter bend by cutting it at an angle and welding it......
Old Feb 28, 2003 | 06:34 PM
420aNT's Avatar
Default Re: Downpipe material needed? (b16ahybrid)
Yeah thats what I did with the downpipe I have now but it doesn't look to hot pieced like that and I would think that it has to be bad for the flow as well.
Old Feb 28, 2003 | 06:38 PM
Smashback's Avatar
http://www.jegs.com
http://www.roadraceengineering.com
If you need a really tight bend RRE has donuts that are badass.
Also, your project might be low end but Burns Stainless is not. They are expensive however.
Old Feb 28, 2003 | 06:47 PM
b16ahybrid's Avatar
Probably flows better then a crush bent pipe!
I'm not complaining, i kind of like the welds, looks custom......oh wait it is huh ....
I've only seen one dp that looked good, it was on a sohc civic (posted on this board) and it was 3''....looked ******* sweet....no welds just a clean 3'' bend.....i still get wood thinking about it....
Old Feb 28, 2003 | 07:24 PM
420aNT's Avatar
bump
Old Mar 1, 2003 | 05:24 AM
420aNT's Avatar
ttt
Old Mar 1, 2003 | 05:53 AM
CzanSOHC's Avatar
yes they do.
http://www.jcwhitney.com/item.jhtml?...=68095&BQ=jcw2
[Modified by CzanSOHC, 6:56 AM 3/1/2003]
Old Mar 1, 2003 | 06:22 AM
420aNT's Avatar
Default Re: Downpipe material needed? (CzanSOHC)
I need a 180' bend
dubseven
Oct 23, 2006 03:53 PM
bigwig
Oct 22, 2003 11:52 PM
Integra808
Apr 12, 2003 05:14 AM
Integra808
Apr 7, 2003 07:34 AM
saso
Jun 6, 2002 04:28 AM
