please help fast......... resistor box wiring problem!!
Old Mar 2, 2003 | 12:18 PM
boostin b16's Avatar
Default please help fast......... resistor box wiring problem!!
can some one please give me accurate wiring instructions for wiring a resistor box to a 00 civic si?
i wiried the box to the yellow and black wires(the only wires that were all the same color) on the harness to the box. then i cut the wire from the injector and left it unconnected. ran the box to a 12v power source and then tried to start the car. no luck!!
whats the problem? TIA
Old Mar 2, 2003 | 12:46 PM
asianspeed's Avatar
Default Re: please help fast......... resistor box wiring problem!! (boostin b16)
This is basically what I did...and it worked.
1) Cut all the yellow/black wires on the injectors.
2) Now you've got 2 set's of 4 wires....one on the injector side and one on the ecu side.
3) Wire the four wires on the injector side to the black wires on the resistor box.
4) Now, wire the remaining 4 wires, going to the ecu, to the one red wire coming out of the resistor box.
You should be good to go!
Old Mar 2, 2003 | 01:53 PM
Default Re: please help fast......... resistor box wiring problem!! (asianspeed)
thanks man! actually i checked your archived post on resistor wiring and got it to work.
thanks again!
Old Mar 2, 2003 | 03:03 PM
asianspeed's Avatar
Right on man!!!
MBlake55
Jul 18, 2008 10:06 AM
7808
Dec 13, 2006 08:52 AM
vladd
Aug 4, 2006 04:28 PM
shivern
Nov 28, 2004 08:51 PM
lilxvtecxpwr
Apr 12, 2004 05:36 AM
