D16Z6 block resistance...
Old Feb 28, 2003 | 07:55 AM
yellowturbo's Avatar
Default D16Z6 block resistance...
Hi guys im new on the board and I found it really nice keep the good job !!!
My question, do I need to put sleeves on my D16Z6 if I run 15 psi...I have JE 9.1, Eagles rods, block guard, brand new engine, ( the interns max is 9 psi haha ), Greddy TD04-15G, type 31 IC, AEM EMS, Rc 550 inj, ....I run at 10 psi last summer without problems... That all you have to know...
Thank for the help...
Mat
Old Feb 28, 2003 | 08:29 AM
genop's Avatar
Default Re: D16Z6 block resistance... (yellowturbo)
You might be able to tune it without sleeves, but I dont think it would last very long....are you using pump gas?? I would get the sleeves before I turned it up to 15psi.
Old Feb 28, 2003 | 09:18 AM
Default Re: D16Z6 block resistance... (genop)
mmh I chek this out
Old Feb 28, 2003 | 11:12 AM
TurbodCX's Avatar
You can do it with no problem!! i ran 20psi on PUMP gas, and i was on stock sleeves with NO blockguard!!!
I dont care what these people say i have DONE it and i ran for a year with out any problems.. i tore it apart to build a bigger better setup..
Brian
Old Feb 28, 2003 | 01:42 PM
ion_four's Avatar
Default Re: D16Z6 block resistance... (TurbodCX)
You ran 20psi on a stock d16? I know someone on here from orlando (forget his handle) is running 1bar and possibly 16psi...what kind of fuel/ignition management and other safety things were you using?
Old Feb 28, 2003 | 02:37 PM
genop's Avatar
do you have a dyno chart of that??
Old Feb 28, 2003 | 02:45 PM
CivicSoul's Avatar
that turbo will suck ***** for 15 psi! It is only good up to 13 psi and that is my goal and your stock block will hold that. I am not to sure about stock rods though.
Old Feb 28, 2003 | 05:08 PM
Default Re: D16Z6 block resistance... (CivicSoul)
Thank turbodcx this makes me more confident now...its great to have the tips from the ones who tried it .... I will give you dyno result ( im on the dyno monday )
Thank !!!!
Old Feb 28, 2003 | 05:16 PM
BoostedED9's Avatar
i dont think the sohc greddy turbo will be good for 15psi.. get a t3t4 and you will be ok... i am the guy runing 1bar that someone mentioned a few posts above...
[Modified by BoostedED9, 9:16 PM 2/28/2003]
Homotor
Dec 4, 2009 12:04 AM
FinalHeaven
Dec 6, 2005 07:50 AM
JdM_Eg_6
Aug 24, 2004 06:13 PM
Civic2Fast
Feb 20, 2003 11:51 AM
td04civic
Mar 19, 2002 11:36 AM
