Will a T25 bolt up to a Greddy manifold
Re: Will a T25 bolt up to a Greddy manifold (photonjedi808)
Those are the turbo's that Greddy uses. But not 100% sure if that year mistu is the right one. Good Luck.
the one greddy manifold I saw was using a T3 style flange.
(bolt hole spaces are about 8cm x 4 cm ).
That one will not bolt to a mitsu-flanged turbo for sure.
Not sure about the other ones.
Also, I don't know if greddy had more than one desing of the manifold.
Re: Will a T25 bolt up to a Greddy manifold (nikitad)
NO, no DSM turbos will fit onto a Greddy, HKS, or APEXi manifold. They all use the standard T-25 Garrett flange. The DSM T-25 is a specially built unit by Garrett for Mitsubishi with their flange. Will not work. This topic has been covered numerous times in the FI forum, and should be common knowledge by now...
Re: Will a T25 bolt up to a Greddy manifold (thaiphob)
Almost, but not quite. It is a mitsubishi turbo built specifically for Greddy w/ a T25 inlet flange.
