Downshifting when braking
Old Mar 2, 2003 | 08:52 AM
B18C-Hatch's Avatar
New User
Default Downshifting when braking
ok i was just wondering if downshifting while coming to a complete stop is good for the engine, i have heard both that it is fine and not a good idea at all (for both NA and FI) which is it?
Old Mar 2, 2003 | 09:43 AM
SJP0tato's Avatar
Default Re: Downshifting when braking (B18C-Hatch)
I would venture it's not good for the engine, but probably not bad for it either. On the otherhand, if your downshift isn't perfectly smooth then it's definately wearing on the clutch. Which would you rather replace more regularly, brakepads, or your clutch?
Just my .02,
Ryan P.
Old Mar 2, 2003 | 09:49 AM
BlueSi2k's Avatar
Default Re: Downshifting when braking (SJP0tato)
It's fine if you do it right. If you double clutched and rev matched perfectly then techically there wouldn't be any more wear on the synchros or the clutch. I always downshift. I usually wont go all the way down to second but if im cruising in 4th gear coming to a stop sign ill put it in 3rd for a little before bringing it to neutral. So if you rev match correctly the only thing that would be wearing is the synchros but I dont really think it would be significant. The synchros are there so that you dont have to double clutch, so if you do then your obviously extending the life, but it would be a pain in the *** to double clutch constantly. HTH
-john
Old Mar 2, 2003 | 11:36 AM
Smashback's Avatar
it's not going to help...but i could hurt, so what's the point?
Old Mar 2, 2003 | 11:44 AM
gsr camel's Avatar
Default Re: Downshifting when braking (Hatchblack)
I always heel toe from 5th - 4- 3 - 2 and extremely rarely to 1st. My clutch is stock and so are my syncro's and they are doing fine with 100K miles and my friend with under 90K that does not race or heel toe has bad syncro's. Just food for thought
Old Mar 2, 2003 | 11:46 AM
BlueSi2k's Avatar
Default Re: Downshifting when braking (gsr camel)
My foots too big to heel and toe...I usually just let off the brake to revmatch. Maybe I need to pick up some racing shoes lol.
Rat Rod
Nov 16, 2010 03:31 PM
oovvutt
Oct 28, 2007 03:45 PM
jairobeatz
Oct 27, 2006 12:25 AM
MiraiZ
Aug 12, 2003 06:18 PM
Astro
Aug 8, 2002 12:05 PM
