Intake control solenoid question
Old Mar 1, 2003 | 11:29 AM
LJR-LUDE01's Avatar
Default Intake control solenoid question
I remove the intake control diaphragm since it was part of my resonator... now I just have the vacuum hose that comes from solenoid valve as you can see from the pic.... what I do with this hose? do I still need to connect this to something? would it affect the car since it not connected no more? this is on a 01 lude
Old Mar 1, 2003 | 11:43 AM
sharkcohen's Avatar
Default Re: Intake control solenoid question (LJR-LUDE01)
The vacuum line runs back up to your intake manifold. Pull the line out of the car and plug the port it ran to on the intake manifold. I noticed in your thread in the Prelude forum that you have a pic of the intake manifold and a plugged port, in which you said you were not sure what the port was for but you plugged it up. That port was the one for the solenoid valve.
Old Mar 1, 2003 | 02:44 PM
LJR-LUDE01's Avatar
Default Re: Intake control solenoid question (sharkcohen)
na it what's plug before I took off the solenoid valve so if I take that one in the pic off I'll 2 port open....
but my main concern is if I take this off would it be ok with the car is not going to cause my a problem in the future... that's what I'm worry about....
[Modified by LJR-LUDE01, 6:45 PM 3/1/2003]
Happy Gilmore
Nov 7, 2008 08:15 AM
killacam661
May 17, 2007 04:26 PM
AccordRacing
May 27, 2005 05:42 AM
93sleeper
Mar 22, 2005 01:50 PM
