Rebuild engine....leave as is....help!
Old Mar 3, 2003 | 01:05 PM
xstalkrx's Avatar
Default Rebuild engine....leave as is....help!
90 ls teg stock cept for cold air and exhaust. 130K miles. Planning on putting a turbo on within a month or two....should i rebuild the engine? i plan on running a conservative 5-7 PSI. What about my rods...will they hold at 5-7 PSI?
Old Mar 3, 2003 | 01:07 PM
b18bturbo's Avatar
Default Re: Rebuild engine....leave as is....help! (xstalkrx)
just check your compression if tis good the ls motor will still be bale to take 5-7psi fine for years.. if the compression is good ...
SnkyPY
Dec 11, 2003 11:55 AM
B_1_8_hatch
Nov 20, 2003 07:52 PM
CobraCommander2
May 22, 2003 01:21 PM
TenaciousC
Aug 20, 2002 10:31 PM
TenaciousC
Aug 20, 2002 05:48 PM
