Shaft Play already?
Old Mar 3, 2003 | 02:39 PM
CRX SiR T's Avatar
Default Shaft Play already?
I've got the basic t3/t4oe that comes w/ some of the pre-fabbed kits. I had the turbo on the car for one day, a little over 2 months ago. i am just now getting the car running again, and i noticed there is shaft play on the turbo! there wasnt any before, and there are fewer than 100 miles on the turbo. there is no play back and forth (<----> ), only up and down.
the only difference is that the houseings were rotated b/c of a different mounting position. Can that cause this? It's pretty noticable too. Is there any way to fix it w/o spending ~300 for a rebuild?
[Modified by CRX SiR T, 11:46 PM 3/3/2003]
Old Mar 3, 2003 | 02:46 PM
boostaholic's Avatar
Default Re: Shaft Play already? (CRX SiR T)
How much can you move it around? As long as it's not scratching the housing a little shaft play is ok.
Old Mar 3, 2003 | 02:48 PM
mamaboy's Avatar
it should be fine. Most used turbos that I hear of have some sort of minimal shaft play. When oil is pressurized into the center housing..this stabalizes the turbine form moving. If the blades are hitting the walls....that's a problem, but otherwise I hear its very normal. If you've pushed your turbo beyond normal driving and dragging I hear it happens....ANY OTHER ADVICES FELLAS?
[Modified by mamaboy, 11:49 PM 3/3/2003]
Old Mar 3, 2003 | 03:05 PM
CRX SiR T's Avatar
Default Re: Shaft Play already? (mamaboy)
i can move it around quite a bit. i've noticed a few scratches in that area that look to be caused from it.
can rotating the housings cause it though?
Old Mar 3, 2003 | 03:14 PM
madman604's Avatar
Default Re: Shaft Play already? (boostaholic)
dont play with the shaft too much, you'll go blind
Old Mar 3, 2003 | 06:08 PM
CRX SiR T's Avatar
any other help?
R6E6I6D
Aug 23, 2005 10:50 PM
LSEGHATCH
Feb 24, 2005 06:44 PM
Vtec92Civic
Dec 15, 2003 05:49 PM
5STAR3
Jul 15, 2003 09:53 AM
