compression test
Old Feb 28, 2003 | 03:45 PM
lsvtec4door's Avatar
Default compression test
whats up...i just did a compression test on my engine ...im using a 95 gsr motor with a drag 3 kit in a 95 hatch the motor has about 70k on it ..i also forgot to pump the gas while i was doing it. anyway the numbers where
cylinder#1...200
cylinder#2...180
cylinder#3...190
cylinder#4...195
anyway are these numbers fine or are they bad...the engine was at normal operating temp... i pulled the ecu plug but i FORGOT to push the gas pedal to full throttle would that effect the numbers...thanks alot let me know
Old Feb 28, 2003 | 07:29 PM
intekragsr's Avatar
Default Re: compression test (lsvtec4door)
well go do it again with at WOT.
Old Feb 28, 2003 | 09:02 PM
BoostingSnail's Avatar
Default Re: compression test (intekragsr)
Holding the throttle wide open will change your numbers slightly but with what you got Id say your good to go.....also with doing the test at WOT it tell the ECU its in clear flood mode where the injectors dont spray...at least Im pretty sure
Old Mar 1, 2003 | 04:30 AM
b18CT's Avatar
Default Re: compression test (BoostingSnail)
who told you that??
Old Mar 1, 2003 | 07:21 PM
Sprockets's Avatar
Default Re: compression test (REVTurbo)
I'd like to know what difference it makes when you hold the throttle open while doing a compression test. People say this is the way it should be done, but I've never heard an explantion. Does anyone know?
Old Mar 2, 2003 | 01:28 PM
who told you that??
On MOST cars when the computer sees a WOT condition on start up it wont send signals to the injectors. you also want to disconnect the coil also.
Holding the throttle open on a compression test just makes sure that the cylinder pulls in a full charge of air on an intake stroke. If you think about it, IF no air could enter the intake mainfold there wouldnt be any air to compress which means no compression..but we all know that air can always get into the intake manifold through many ways which is why you get compression with the throttle closed....hope that cleared quesitons up
Old Mar 2, 2003 | 01:31 PM
Stewie's Avatar
Do a leakdown test #2 looks low
Old Mar 2, 2003 | 04:30 PM
MachAF's Avatar
who told you that??
Umm thats why you take out the fuel pump fuse. So you don't get fuel why cranking.
Old Mar 2, 2003 | 05:55 PM
Sprockets's Avatar
Default Re: compression test (machaf)
That's what I did. I pulled the fuse, took out every spark plug, cranked it over 5 times and got about 210 on every cylinder without flooring the car. Would it really make any difference if I hold the throttle open?
Old Mar 2, 2003 | 06:59 PM
BoostedSi's Avatar
Default Re: compression test (Evil Beaver)
those numbers dont seem too bad
97civic07gsxr
17
Mar 5, 2009 12:30 AM
92siracer
Jun 2, 2004 10:29 PM
lsvtec4door
Mar 4, 2003 06:13 AM
lsvtec4door
Feb 28, 2003 04:01 PM
jaredfmn
May 30, 2002 11:33 AM
