ECU questions for Hondata For Non-Vtec
Which ecu should i run for my LS? I've heard the p28 is a great ecu for hondata, but will it mess with anything, since its vtec?? Which ecu should i run w/ my car?
Re: ECU questions for Hondata For Non-Vtec (integranator)
Well, umm.... THE LS ECU!!!! It's the ECU for your car and you won't have to modify anything except for the chip and the jumper (depending on which system you are getting) soyou send your ECU to hondata and give them $50 and there you go, your all set! Hope this helps.
Later,
Sean C.
Later,
Sean C.
Re: ECU questions for Hondata For Non-Vtec (ekb18c)
Im pretty sure I have my hondata sold. So Im willing to part with my chipped LS P75 hondata ecu. Let me know what you think. You will need a conversion harness for this since its OBD1.
Dan
Dan
