Spark Plug question
Old Mar 3, 2003 | 12:16 PM
underpressure02's Avatar
Default Spark Plug question
Does anyone know what plugs to run in a stock ls motor with a drag gen III turbo kit.
My old motor that had some internal work done to it had NGK BCPR7ES in it
When I pulled the plugs in the new stock(junkyard) motor I see they have NGK ZFR5F in it.
I am running between 7 and 10 psi. I just want to make sure I am running to correct heat range in the car.
Thanks
[Modified by underpressure02, 4:20 PM 3/3/2003]
Old Mar 3, 2003 | 01:02 PM
Pengo's Avatar
Default Re: Spark Plug question (underpressure02)
i think your plugs are backwards. your all motor shouldve been running the 5s and the boosted one 7s
Old Mar 3, 2003 | 01:08 PM
b18bturbo's Avatar
Default Re: Spark Plug question (Pengo)
you need bcpr7es11 or bkre7
Old Mar 4, 2003 | 06:44 AM
So the 5s I was running would have been a hotter plug?
So I am correct running the 7s that I posted in my orginal thread? That is the correct heat range and what not.
[Modified by underpressure02, 11:30 AM 3/4/2003]
Old Mar 4, 2003 | 06:49 AM
Pengo's Avatar
yup, the lower number is hotter, and the higher the colder. the 7's should be fine
Old Mar 4, 2003 | 06:51 AM
b18bturbo's Avatar
Dont try those with domestic plugs they are backwards...
Old Mar 4, 2003 | 07:25 AM
Default Re: Spark Plug question (b18bturbo)
I run NGK in my snowmobiles and I was trying to rember how the number range worked on them. Thanks for the info
Old Mar 4, 2003 | 07:34 AM
DBallz's Avatar
NGK stock number 1095
Old Mar 5, 2003 | 10:40 AM
okay I talked to a few people and they are saying I should be running 8's what are the opions on this?
Old Mar 5, 2003 | 10:58 AM
b18bturbo's Avatar
thats way too cold for just low boost applications .. no need for 8 plug only race guys and crzy peeps like me run that ****...
Old Mar 5, 2003 | 11:02 AM
k b/c my worry is that i hear what I believe is detoniation. So that is why someone said this. Currently trying to figure out my aem ems so fix the problem. Just trying to protect this motor. But thanks for the info.
Old Mar 15, 2003 | 06:25 PM
One other thing. Does anyone know what the plug gap should be? TIA
Old Mar 16, 2003 | 02:51 PM
Pengo's Avatar
i run .032-.034 but that's on my sohc. i dunno what other b-series are runnin
Old Mar 16, 2003 | 03:26 PM
TurboDANDEE's Avatar
i run NGK non-platinum 9 heat range and my gap is at 28.
FAmou5
11
Mar 2, 2010 01:16 AM
TEG777
Oct 3, 2005 04:43 PM
TurboBumblBee
Sep 1, 2003 11:01 AM
YellowR2000x2
Mar 31, 2003 02:31 AM
TurbothisLS
Sep 9, 2002 12:39 PM
