turbo noob help...
Old Mar 1, 2003 | 03:58 PM
bad 2 the B-ONE ej1's Avatar
Default turbo noob help...
ive got an LS swap in my 95 civic coupe. all stock internals and stock head. what kind of boost will the stock bottom end hold? im looking at running around 10-12 lbs, what kind of work needs to be done to the bottom end and head to support that much boost and what kind of 1/4 mi times am i lookin at? what size injectors will i need? and will i need to upgrade the fuel pump or anything else in the fuel system...
thanx for the help, cam
Old Mar 1, 2003 | 07:15 PM
smallttocs's Avatar
Default Re: turbo noob help... (bad 2 the B-ONE ej1)
10-12 is pushing it on stock internals imo. and 440cc injectors should be used.
Old Mar 1, 2003 | 09:59 PM
SoulSurfer's Avatar
Default Re: turbo noob help... (smallttocs)
A lot of people are running 10-12psi on stock internals with no issues. In the end it all comes down to tuning.
I've got the same motor and will probably run about 10psi. I've got Zip's SMC (soon to upgraded to the SMC500) and 450CC DSM injectors.
If you go the route of a standalone or FMU you will need either an intank or inline fuel pump.
[Modified by LSDelSol, 6:37 PM 3/2/2003]
Old Mar 1, 2003 | 10:13 PM
DIRep972's Avatar
Smarter than you
I wouldnt try 10-12psi on a stock motor w/ out standalone. The key to running high boost on stock internals is in the timing map. a/f is obvious, but running conservative timing is key. This is something u can only do effectively w/ a standalone.
550cc injectors, walbro intank fuel pump, and hondata s200b was enough to get the job done for me. I run 12psi daily stock LS motor. but w/ out standalone w/ a basic fmu set up boost should be kept low, 7-8psi range.
[Modified by DIRep, 11:14 PM 3/1/2003]
Old Mar 1, 2003 | 10:16 PM
LS-T's Avatar
New User
its gonna varies....all based on the tuning!
blackfoot
Jan 22, 2006 08:01 AM
NightKids
May 5, 2003 09:41 AM
X2BOARD
May 6, 2002 03:02 PM
freakie
Nov 8, 2001 08:39 AM
Reverend
Aug 28, 2001 09:27 PM
