Mechanical Or Electronic Gauges??
Old Feb 28, 2003 | 06:44 AM
integranator's Avatar
Default Mechanical Or Electronic Gauges??
Which do you recommend?? What is the benefit of either. Ive heard that if you run a mechanical boost gauge, you hve to run a vaccuum line into the car? So which do you guys prefer?
Old Feb 28, 2003 | 06:47 AM
98Psi ITR's Avatar
Default Re: Mechanical Or Electronic Gauges?? (integranator)
electrical>mechanical
Old Feb 28, 2003 | 07:00 AM
PM-Performance's Avatar
Default Re: Mechanical Or Electronic Gauges?? (98Psi ITR)
i have all elect except boost becuase i couldnt see spending the extra money on it , reguardless you gonna run some sort of vac line wont you ?
i just wouldnt do it with fluid tranfer, ie, fuel , oil pressure, etc.
Old Feb 28, 2003 | 07:33 AM
Default Re: Mechanical Or Electronic Gauges?? (itr206)
Yes, you would-- but w/ an electric, you don't have to run the vac line into the car, correct?
Old Feb 28, 2003 | 07:36 AM
you shouldnt , but i dont see the issue with a vac line . i put mine in some wire loom just to make sure it didnt get fucked up thru the firewall and routed it nice under the dash , mine came out clean and nice , im very particular how i route things. esp soemthing that can get damaged.
But yes the elec bost gauge , prob has like an elec sending unit of some sort, where it will get a vac line into it and thne change the signal from Mech to elec and send it into the cockpit via 2 wires, or 1 wire.
boost isnt as crucuail with the elec vs mech situation . imo at least.
Old Feb 28, 2003 | 07:37 AM
thats cool, just worried about the hassle-- but it seems like there's not too big of one!
Old Feb 28, 2003 | 09:12 AM
Pengo's Avatar
for oil and fuel i like elec but for boost i like mech
Old Feb 28, 2003 | 10:55 AM
blufke's Avatar
Default Re: Mechanical Or Electronic Gauges?? (Pengo)
thats what im thinking, dont want something to spring a leak and get inside all over the dash and never be able to clean it all out.
Old Feb 28, 2003 | 11:03 AM
bruthaboost's Avatar
I have mechanical for boost and electric for oil pressure and temp, fuel pressure and egt. Honestly I like the response of mechanical better and I think it's less hassle (wiring) using mech over electrical. I wouldn't worry about leaking. The lines use compression fittings.
K i l l a B e e.
Oct 29, 2007 08:56 AM
ericstambaugh07
May 22, 2007 06:45 PM
blackccoupe
May 18, 2004 07:26 PM
TheIntegraGuy
Nov 23, 2002 07:43 AM
Pengo
Jul 23, 2002 09:35 AM
