apexi safc 2
Old Mar 1, 2003 | 01:24 PM
Drkaccrd's Avatar
Default apexi safc 2
Alright guys & gals has anyone had a chance to try the new SAFC II ? If so what do you think versus ver. 1?
Old Mar 1, 2003 | 01:29 PM
Adriano's Avatar
Default Re: apexi safc 2 (Drkaccrd)
I believe with the new s-afc II you can adjust the fuel every 200rpm while the s-afc adjusted every 500rpm. I figured it should be a little harder to adjust, but will be more accurate.
Old Mar 1, 2003 | 01:34 PM
avividmemory's Avatar
Default Re: apexi safc 2 (brryder)
If you can hold out til next weekend I'll let you know... Just waiting for a little warm-up to put the motor back in!
Old Mar 1, 2003 | 03:47 PM
LshatchTurbo's Avatar
New User
Default Re: apexi safc 2 (SpoolinLS)
You can also store two separate settings, and switch between them....pretty cool. Should have included this feature in the first version. Maybe have one setting tuned for street and low boost, and for the track and high boost
Old Mar 1, 2003 | 06:26 PM
Broken Gearbox's Avatar
Default Re: apexi safc 2 (lshatchturbo)
can you use one setting for NA and the other setting for N20???...also whered you guys get em at??
Old Mar 1, 2003 | 07:16 PM
New User
Default Re: apexi safc 2 (x lP lL i c i t)
I dont see why not... essentially you just storing two completely separate values. But i dont know if you have it automatically switch settings when it sprays.. that be pretty sick
Old Mar 1, 2003 | 08:21 PM
Drkaccrd's Avatar
hey spoolinls keep me posted . Let me know if the wiring harness is the same too. Cause if I end up buying it I dont wanna have to re-wire cause I already have the safc 1 installed.
Old Mar 2, 2003 | 07:48 AM
I think the harness is basically the same, only difference is one added wire for knock or warning feature...
TranspeedMotorsports
Aug 26, 2006 01:04 AM
Mugencrxsir1
Apr 12, 2006 07:58 AM
killa_lude
Jan 21, 2004 08:35 AM
ForcedAccord
Nov 8, 2001 12:59 PM
ACURACY_VTEC
Oct 20, 2001 10:28 AM
