Threaded IAT sensor compatible with B16A?
Old Mar 3, 2003 | 09:00 AM
Sprockets's Avatar
Default Threaded IAT sensor compatible with B16A?
Does anyone know if Honda/Acura threaded IAT sensors would be compatible with my 99 Si? I'd like to just weld an aluminum bung on the intake and thread it in for a clean install. I think falconGSR did it with a GM sensor, but he has AEM EMS to adjust the voltage. Where would I look to find the differences between Honda's sensors?
Old Mar 3, 2003 | 09:03 AM
Flamenco-T's Avatar
Default Re: Threaded IAT sensor compatible with B16A? (Evil Beaver)
your IAT is not in the intake manifold ? usually it is held by 2 small bolts 4x.7mm
Old Mar 3, 2003 | 09:15 AM
Sonny's Avatar
Default Re: Threaded IAT sensor compatible with B16A? (Flamenco-T)
On the 99-00 Civic Si, the IAT is located in the rubber intake boot.
Yes, you can use an OBD1 style IAT sensor with no problems.
Sonny
Old Mar 3, 2003 | 09:44 AM
Sprockets's Avatar
Default Re: Threaded IAT sensor compatible with B16A? (Sonny)
I just assumed that they threaded into the manifold. Are they bolted in? Which OBD1 sensor should I order (which car)? Thanks for the help!
Old Mar 3, 2003 | 09:47 AM
sgT's Avatar
sgT
any 92-95 civic or 94-01 integra
Old Mar 3, 2003 | 06:08 PM
Sprockets's Avatar
Default Re: Threaded IAT sensor compatible with B16A? (sgT)
Thanks, sgT! This link has a picture of a '95 Civic intake manifold, but the picture is pretty bad. It looks like the sensor bolts on, though. I'm looking at part #11 here:
http://www.hondaautomotiveparts.com/...NTAKE+MANIFOLD
Am I looking at the right part?
Old Mar 3, 2003 | 06:42 PM
Mikey3000's Avatar
yeah its #11 in that pic. all Honda/Acura IAT's are the same and will work in any other Honda/Acura. 2 screws hold it on.
Old Mar 4, 2003 | 07:46 PM
Sprockets's Avatar
Default Re: Threaded IAT sensor compatible with B16A? (Salvatore Leone)
Thanks, that's exactly what I wanted to know! I'm going to stick with what I have, it seems to be holding well.
crist488
11
Jul 15, 2011 09:26 PM
bringmyownend
Dec 16, 2010 08:25 PM
tigueremalo
Nov 10, 2007 04:42 PM
6doorsentra
Sep 6, 2006 02:53 PM
90ZCREX
Sep 27, 2005 10:33 AM
