noob ?'s
Old Mar 1, 2003 | 07:44 PM
RedDawg's Avatar
Default noob ?'s
For the next year i plan on building a turbo motor to swap into my 95 teggie.
I'm going to get a B18b and use a drag III kit on it. I want to be able to run 10psi daily and turn it up to around 16psi for track days so obviously i'll need to build the engine. Right now i plan on using:
JE 9:1 pistons
Crower Rods
310cc injectors
Hondata (which one ??)
turbo timer
boost gauge
air/fuel gauge
STR block guard
ACT Heavy duty/6 puck clutch
ARP head studs
Will this setup be able to handle the higher boost setting?? What other gauges do i need? I'm going to take my time, and if i need to hold off longer inorder to save more $ for a better buildup i will do it
[Modified by RedDawg, 4:52 AM 3/2/2003]
Old Mar 1, 2003 | 07:58 PM
MiraiZ's Avatar
Default Re: noob ?'s (RedDawg)
lose the blockguard and get bigger injectors
Old Mar 1, 2003 | 11:43 PM
RedDawg's Avatar
Default Re: noob ?'s (MiraiZ)
what size injectors should i get?
Old Mar 2, 2003 | 02:33 AM
MiraiZ's Avatar
bigger the better....but if you are on a budget, the DSM 450's is a good inexpensive starter
Leplease
May 27, 2019 05:14 AM
kcfoodsci
Aug 18, 2016 08:51 AM
jamesfawcett
Apr 13, 2010 01:33 AM
TURBO B
Sep 24, 2003 09:08 AM
93B17A
Feb 27, 2002 06:57 PM
