B20a crank in a C5 block?
Old Mar 3, 2003 | 02:20 PM
scooter's Avatar
Default B20a crank in a C5 block?
I searched on this topic and didnt find too much info.
I have a GE sleeved C5 block which I will be building for a turbo application and I also have a B20a crank lying around so I was curious if anyone had done this with custom rods and pistons before?
This is assuming the crank is totally balanced.
scott
Old Mar 3, 2003 | 02:27 PM
inspyral's Avatar
Default Re: B20a crank in a C5 block? (scooter)
Isn't the B2 crank the same as the B18A/B crank? I believe you just use LS/B20 rods with that crank in a C5 block.
Old Mar 3, 2003 | 02:31 PM
boostaholic's Avatar
The B20a crank is from the earlier preludes and is way different than the B18a/b/B20b/z cranks. I believe the b20a blocks also had a girdle across the main caps. The b18a/b and b20b/z cranks will go into the b18c5 block, but i'm not sure about the b20a crank.
Old Mar 3, 2003 | 02:33 PM
liam821's Avatar
25 Year Member
Default Re: B20a crank in a C5 block? (inspyral)
b20a != b20b or the b20z. The b20a is out of the old old prelude 2.0 dohc. Its a pos. I believe the b20b/b20z cranks are the same as the b18a/b18b. (correct me if im wrong)
Although crower used to use the b20a crank (with some machining i think) to fit in a b16/b18 with special rods...and it would increase the displacement .2. So a 1.6 -> 1.8 and a 1.8 -> 2.0.
I really dont know what you need..crower doesnt use that crank anymore in thier stroker kits because its hard to get ahold of.
liam
Old Mar 3, 2003 | 02:34 PM
scooter's Avatar
Default Re: B20a crank in a C5 block? (boostaholic)
I would not ask the question if I wasnt sure that the crank would go into the block. The answer is yes it will fit the block.
The B20a is from a 88-91 prelude and has a longer stroke than the B20b/z.
scott
Old Mar 3, 2003 | 02:54 PM
CRVRX's Avatar
B20A motor is a 2.0L with a 81mm bore , the B20B+Z is a 2.0L with a 84 mm bore. Yes the crank has a longer stroke , I 'm not sure who has the pistons and rods for it.
And I belive the question was not " is the B20A motor good?"
I'm sure someone out there will have the anwser , and not just make stuff up they know nothing about.
Old Mar 3, 2003 | 03:02 PM
liam821's Avatar
25 Year Member
Default Re: B20a crank in a C5 block? (CRVRX)
I just said crower made a stroker kit for that [b18a] crank in a b16 b18 motor...or maybe you didnt read that?
liam
Old Mar 3, 2003 | 03:26 PM
CRVRX's Avatar
Default Re: B20a crank in a C5 block? (liam821)
liam821, I wasn't quoting you , I was just making a point so it didn't start into evreybody guessing at stuff.
Old Mar 3, 2003 | 03:30 PM
liam821's Avatar
25 Year Member
liam
93xsi
Oct 18, 2010 09:42 AM
HiGhOkTaNE
Jun 12, 2007 11:48 AM
scooter
Mar 4, 2003 11:05 PM
Bnjmn
Jan 23, 2003 09:30 AM
