What causes low EGT's?
Old Mar 1, 2003 | 09:43 AM
IloveNewt's Avatar
Default What causes low EGT's?
I just picked up my car from the shop. I am getting very low egt's in the 500 degrees C range when im on the highway MAX. What could cause this besides the car running rich.
The CE light is also on, i havent had a chance yet to get the code, i will post it up here where i can get to the car.
Old Mar 1, 2003 | 09:45 AM
DIRep972's Avatar
Smarter than you
Default Re: What causes low EGT's? (MordecaiPSI)
where is the probe installed?
Old Mar 1, 2003 | 09:49 AM
boosted hybrid's Avatar
My best guess would be the placement of the egt probe. If you have low egt's then the timing is through the roof, or you are running rich. I still say its placement. Best place for probes is 1" from the head of the block on the manifold.
Old Mar 1, 2003 | 11:46 AM
move_right's Avatar
yeah, that probe has GOT to be 1-2 inches from the head of the manifold for a normal reading.
Old Mar 1, 2003 | 01:04 PM
drift's Avatar
New User
Default Re: What causes low EGT's? (vinny)
running very rich or a retarded ignition setting reduces EGT's due to incomplete combustion.
lean conditions increase EGT's, along with poor charge cooling.
Old Mar 1, 2003 | 01:16 PM
93LSivic's Avatar
Default Re: What causes low EGT's? (drift)
Actually, a very rich condition would cause a high EGT reading.
Old Mar 1, 2003 | 01:21 PM
falcongsr's Avatar
What is this crap?
Default Re: What causes low EGT's? (93LSivic)
why
Old Mar 1, 2003 | 01:22 PM
falcongsr's Avatar
What is this crap?
what? why
Old Mar 1, 2003 | 01:32 PM
Mammad's Avatar
Default Re: What causes low EGT's? (falconGSR)
Low Fuel cuases Low EGT
Old Mar 1, 2003 | 01:34 PM
93LSivic's Avatar
why
Cause the unused gas ignites in the manifold.
Old Mar 1, 2003 | 03:41 PM
LshatchTurbo's Avatar
New User
I was almost positive that a retarding ignition tends to raise EGT's....thats how it is in my car to a point.
[Modified by lshatchturbo, 7:45 PM 3/1/2003]
Old Mar 1, 2003 | 03:48 PM
falcongsr's Avatar
What is this crap?
why
ok so the cylinder temps themselves are ridiculously low in this case, even though the manifold is heating up...i always assumed this was very rare and you'd start to get rich misfire before things got this bad.
retarding timing can raise EGTs. adding fuel lowers EGTs in the normal tuning / operation window of the engine. at the extremes all bets are off.
Old Mar 1, 2003 | 03:53 PM
UberTeg's Avatar
Default Re: What causes low EGT's? (lshatchturbo)
Retrding timing DOES increase egt's. Because the mixture is ignited closer to the point where the exhaust valves open.
Old Mar 1, 2003 | 04:24 PM
b18cTurbo's Avatar
Default Re: What causes low EGT's? (UberTeg)
damn alote of missinformation here
retarding will cause high to very high egt's
running rich will lower egt
running stoich will cause very high egt's
running very lean ,no more fuel =lower egt's
less gapping (spark plug)=higher egt's
i have experienced all of does
Old Mar 1, 2003 | 04:43 PM
IloveNewt's Avatar
Default Re: What causes low EGT's? (C5turbo)
Hmm, well im my case, the low EGT is along with the CE light. The CE light went away by itself now. But the EGT's r still very low, does not go over 600 degrees C. So i reset teh ecu, but same thing. What could be causing this?
Could a bad distributor cause this in some way? I can tell my distributor is on its last breath, but coudl it cause the low egt?
Or indirectly, coudl the bad distributor cause the CE light which in turn cause the car to run in limp mode and cause a rich mixture?
Old Mar 1, 2003 | 04:54 PM
New User
He just explained why!
[Modified by lshatchturbo, 8:56 PM 3/1/2003]
krytykalintentions
Mar 23, 2007 12:48 PM
Jet Black
Nov 25, 2006 06:49 PM
ham
17
Jun 20, 2004 08:09 PM
shamoo
Sep 30, 2002 06:38 AM
syeve
Jul 13, 2002 03:33 PM
