can i still use this turbo
i have a gsr turbo with the drag gen3 kit...i'm gettin rdy to buy a built bottom end..dart tall deck with pistons/rods/crank...i wanna go to a 2.1 with prob 9.0.1comp and rework my gsr head...can i still use my drag turbo will it spool faster or not as good...i'm thinkin i wanna run up to 25psi on the new motor..this drag turbo should be good for this set up right
Re: can i still use this turbo (lucidvtec)
yeah, you can still use the turbo, but you won't get all the power that your motor is capable of handling with that turbo
to get the amount of power that the motor is capable of, you will want a much bigger turbo and good engine management and fuel if you dont already have it
Turbo-Mind
04-03-2003 11:53 AM
