Hondata+ Emissions in CT
My friend has a 2000 civic Si with a JRSC and hondata. She went to CT emissions today and failed due to her ecu not responding. How are all you CT people with 96+ newer cars and aftermarket ecu's passing emissions ????
Who is Mr Robot?
Re: Hondata+ Emissions in CT (TurBoTeG)
you cannot pass the obd2 ecu check without the original oem obd2 ecu.
ziptie the bypass vavle open on the jrsc or just take the belt off. put the stock injectors and the stock ecu back in. go drive it a little bit then get tested, you should pass then... nuff said. put the hondata back in and reinstall everything
blkb18
02-17-2008 03:57 PM
