Thought I'd share my 15g greddy kit on z6 dyno numbers
Finally got my car tuned on 8 psi. I planned to tune on 10 psi but it would creep up to 11 psi and then fall back down to 8 almost immediately. I think these numbers are pretty good for only having 4 dyno pulls and hurrying to get out of there before the dyno closed. This was tuned by 93turbo16 in 100 degree heat with 90% humidity. On 10 psi, do you guys think I'll make it to the magical number of 200whp?
Re: Thought I'd share my 15g greddy kit on z6 dyno numbers (PA MATT)
good numbers john tuned my car too, yours is tuned extremely conservitavely based on the a/f's so i'm sure 200is in your future
Great numbers man! I have the same problem with mine spiking to what i want it to go to and then dropping back to 8psi...even with a 10psi spring .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16Civic93 »</TD></TR><TR><TD CLASS="quote">good numbers john tuned my car too, yours is tuned extremely conservitavely based on the a/f's so i'm sure 200is in your future</TD></TR></TABLE>
how do you figure the a/f's to be conservative? They look right around 12:1 to me. Extremely conservative would be more like 10.5:1-11:1.
Your WG actuator is on its way out.
Make sure you keep an eye on it.
My pal blew his motor with greddy kit recently due to this.
Spiked to around 15 in 5th gear.
Re: Thought I'd share my 15g greddy kit on z6 dyno numbers (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue »</TD></TR><TR><TD CLASS="quote">
how do you figure the a/f's to be conservative? They look right around 12:1 to me. Extremely conservative would be more like 10.5:1-11:1. </TD></TR></TABLE>
agreed
agreed
Guest
Posts: n/a
Re: (Dr. D-Series)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr. D-Series »</TD></TR><TR><TD CLASS="quote">Your WG actuator is on its way out.
Spiked to around 15 in 5th gear.</TD></TR></TABLE>
uhh mine is brand spankin new...i dont think so. thats how it is with manual boost controllers. with electric, no..
Re: (mike93eh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh »</TD></TR><TR><TD CLASS="quote">
uhh mine is brand spankin new...i dont think so. thats how it is with manual boost controllers. with electric, no..</TD></TR></TABLE>
i agree MBC's tend to do that...
what i found helpful was placing the controller closer to the vacuum source and shortening the amount of vacuum line. see if it helps....
-Rage
BTW-sweet numbers(PA MATT), but i think u can do better. if u have time check my threads on my SOHC numbers from back BACK in the day
-Rage
Guest
Posts: n/a
Re: (Racerage1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Racerage1 »</TD></TR><TR><TD CLASS="quote">i agree MBC's tend to do that...
-Rage
BTW-sweet numbers(PA MATT), but i think u can do better. if u have time check my threads on my SOHC numbers from back BACK in the day </TD></TR></TABLE>
mine is already within a couple inches form it so...
-Rage
Well my pals was a used kit.
With no MBC at all.
Just kept getting worse day by day.
I wasnt saying ur kit is ****, just letting you know a personal experience. Thought id just contribute.
With no MBC at all.
Re: (Dr. D-Series)
I just bought an ebc, but the mbc i have is all the way up on the firewall so could be part of the problem. That and its a homemade controller. John also told me that he could have gotten more power from other places had we had more time.
Re: (PA MATT)
I went ahead and just got rid of a boost controller and adjusted the wastegate arm instead. Worked much better for me. I had tried a turbo xs hp and a greddy profec a. Had problems with both.
Haleiwa-Brando
05-10-2006 02:26 PM
