fuel pump install
Old Jul 7, 2005 | 08:01 PM
civiclx97's Avatar
Default fuel pump install
hey guys my missing link is coming in tomorrow and i will finally be able to run under some boost...so i figured i should probably have the inline fuel pump installed that came with my drag III kit? to install it do i just cut the feul line that goes from the feul filter to the fuel rail and stick both ends of the hose on the inlet and outlet of the pump?does it matter that the outlet is much bigger than the inlet will the hose still fit on the outlet side? also where does the positive wire go...i know it goes to the pgmfi but can it go somewhere easier? any experience with a drag kit on a stock b16, like hp and torque number wise...right now im running 6 psi but will probably bring it to 7.5 or 8?
Old Jul 9, 2005 | 07:01 AM
civiclx97's Avatar
Default Re: fuel pump install (civiclx97)
anybody?
Old Jul 9, 2005 | 07:58 AM
notoriousB's Avatar
you've got it, just cut the line and put it in. my inline pump w/ the drag kit came with a few different size fittings I just used the ones that worked for my motor. connect the positive wire to the fuel pump output on the main relay under the dash and the negative to a good ground in the engine bay. don't go too high w/ the boost on the FMU, 7psi is about as far as i'd go with the inline pump/fmu combo.
89civic1.8T
Aug 31, 2002 12:35 PM
TORQUE MONSTER
Aug 15, 2002 05:15 AM
tygsr
May 11, 2002 04:14 PM
