rubber intercooler piping???
Old Jul 7, 2005 | 03:36 PM
misskris220's Avatar
Default rubber intercooler piping???
im putting together a turbo kit and someone threw out the idea of using rubber hoses as intercooler piping. it kind of makes sense that it would work but i have never heard of it. i was wondering if anyone had ever seen this done or if you think it would work.
Old Jul 7, 2005 | 04:27 PM
omahaturbocivic's Avatar
Default Re: rubber intercooler piping??? (misskris220)
Silicone hose works, rubber is a bad idea and does not even work well for couplings. As rubber heats up it becomes very soft and will slip off of whatever its clamped to when it gets hot, if you tighten it tight enough it does not slip off it will end up tearing off. This is just when used as short 3 inch couplings, larger lenghts will probably expand a lot once they get hot as well as the previous problems.
Old Jul 7, 2005 | 04:50 PM
turbosi03's Avatar
Default Re: rubber intercooler piping??? (omahaturbocivic)
nope. don't do it... you need something that will hold pressure, not something that will expand on you... not to mention that it will try to straiten out on you under boost like a fire hose...
Old Jul 7, 2005 | 04:54 PM
mike1114's Avatar
Default Re: rubber intercooler piping??? (turbosi03)
I have some silicone 45 degree bends that I use to get around a corner on my setup. About 4-5 inches is just coupling, no piping. It doesn't expand but I would not try a length anymore than this. This is runing 15psi by the way.
cbstudd77
Nov 29, 2006 05:38 AM
93_teg_CT
Jun 2, 2006 11:51 PM
corey's96GSR
May 1, 2004 11:06 AM
ID_ten_T
Aug 14, 2003 04:58 PM
VTEC-DA
Feb 5, 2003 09:35 AM
