MSD digital window switch
Old Jul 9, 2005 | 03:25 PM
e jay one's Avatar
Default MSD digital window switch
i just hooked up an msd digital window switch and it works but i am having trouble adjusting it. when i press the mode button the light flashes for the on rpm but i cant adjust it same with off rpm and cylinder. its like the up and down buttons dont work. what am i doing wrong? thanks
Old Jul 9, 2005 | 06:23 PM
e jay one's Avatar
Default Re: MSD digital window switch (e jay one)
Old Jul 9, 2005 | 06:47 PM
DaveF's Avatar
digital ? do you have a link or a picture of this... id like to see it. (never heard of it or used one)
Old Jul 9, 2005 | 08:11 PM
e jay one's Avatar
Default Re: MSD digital window switch (Dturbocivic)
this is the one i got
http://www.jegs.com/cgi-bin/nc...r=361
it can be adjusted by 100 rpms rather than the pills. but it dosnt work and i gotta wait till monday to talk to some one from msd.
Old Jul 9, 2005 | 08:17 PM
SOHCmaster's Avatar
MSD has a good support page with help and troubleshooting.
Old Jul 10, 2005 | 05:46 AM
DaveF's Avatar
http://www.msdignition.com/pdf/8969_frm25515.pdf
PROGRAMMING THE RPM
The rpm activation points and cylinder
select are programmed
through the push buttons on the
LED panel (Figure 1). Press the
Mode button, and notice that the
indicator light above the On RPM
lights. When that point is on, you
can scroll the rpm value up or
down with the arrows on the left
of the panel. Once your On rpm
is set, push the Mode button until
the Off RPM point lights, then set
the Off rpm point. Note that if the rpm point is not changed within 2-seconds, the screen returns to
the current rpm reading (zero when the engine is not running). After setting the On and Off points,
press the Mode button to program the Cylinder Select Valve (default is for 8-cyl.)
Old Jul 10, 2005 | 09:15 AM
e jay one's Avatar
yea i got all that in the instructions but the problem is the up and down buttons dont work. when i go to select the rpm i press the buttons and nothing happens. but i can go through the modes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PK SPEED &raquo;</TD></TR><TR><TD CLASS="quote">MSD has a good support page with help and troubleshooting.</TD></TR></TABLE>
yea but nothing about the window switch. they also have an extremely slow forum
Old Jul 10, 2005 | 10:36 AM
DaveF's Avatar
what happens if you push and hold the mode button? do the indicator lights light up when you get to "rpm" ??
Old Jul 10, 2005 | 01:38 PM
e jay one's Avatar
the little light blinks. right now its on default wich is of course v8 mode. trust me ive tried everything. press and hold, press real fast, hold one and press another. im pretty sure its defective so now i gotta wait even longer to send it back to get fixed
BoredNStroked
Mar 12, 2006 09:36 PM
ubnpast
May 17, 2004 06:05 PM
RedDawg
Apr 1, 2002 04:31 PM
LshatchTurbo
Feb 23, 2002 10:13 AM
