internal or external wastegate?
Old Jul 11, 2005 | 03:29 PM
KURUPTinc's Avatar
Default internal or external wastegate?
Hey guys just wondering what would be better for a sohc d16 stock internal motor. an internal or external wastegate?
Old Jul 11, 2005 | 04:00 PM
KingElli's Avatar
How many lbs do you plan on boosting? High boost i'd go external, lower boost around 5-9psi internal should be fine except for the occasional boost spike depending on whcih turbo u are using.
Old Jul 11, 2005 | 04:05 PM
B6tPoweredMx3's Avatar
Default Re: (KingElli)
Id run an external, just for sheer adjustability.
Old Jul 11, 2005 | 04:16 PM
Blaze45's Avatar
Brrraaaap!
Default Re: (B6tPoweredMx3)
External, placed correctly is supposedly better. I cant back that up but Ive read of people running internal WGs on older turbos and they seems to have boost creep/spiking issues.... I know my buddy has. Im running the 38mm Tial and Ive never had any issues...
Blaze
Old Jul 11, 2005 | 08:58 PM
KURUPTinc's Avatar
Default Re: (Blaze45)
can u adjust boost on internal?
Old Jul 11, 2005 | 09:11 PM
5thGenCivicKid's Avatar
Default Re: (KURUPTinc)
go external the internals all get in the way when mounting the turbo
Old Jul 11, 2005 | 09:28 PM
B18badboy's Avatar
Very true, I punctured my rad with my internal wg actuator
Old Jul 11, 2005 | 09:45 PM
coupe99vtec's Avatar
don't mean to jack but i got a question along the lines...
If u buy a turbo with an internal wastegate cna u just rip the actuator and the arm off of it and some how close up the wastegate? also i heard that if you ARE gunna use an internal wastegate i heard that u need a custom turbo manifold to allow for the bigger flange?
info would be awesome!
Old Jul 12, 2005 | 04:40 AM
Default Re: (rentacar4dr)
Ive seen people make an internally wastegated turbo external. It usually involves removing the arm and leaving the flapper and just welding that to the exhaust side, Which is usually cast . Just buy a turbo thats already externally wastegated.
Old Jul 12, 2005 | 06:38 AM
95civ's Avatar
yeah...i'm basically done with my turbo build, i just can't adjust my turbo to a good position for some reason with an internal wastegate. I've gotten advice to make the arm a little longer so the wastegate sits a little farther away from the turbo. It's just more of a hassle, if i could do it over again, i would've went with an external wastegate.
Old Jul 12, 2005 | 06:53 AM
EJ1 wilcox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rentacar4dr &raquo;</TD></TR><TR><TD CLASS="quote">don't mean to jack but i got a question along the lines...
info would be awesome!</TD></TR></TABLE>
It depends on the turbo. On my turbo (T3 .48/.60) the internal wastegate actuator and flapper were all removable from the turbo. All I had to do was unbolt them and take them off to run an external wastegate.
About the "custom" turbo manifold for an internal wastegate. Not true at all. The turbine inlet flange is the same for internal and external wastegate turbos. The only thing different about the manifolds is, with an external you have to have an external wastegate flange on the manifold, and with an internal wastegate you don't need that flange on the mani.
Old Jul 12, 2005 | 07:28 AM
Default Re: (EJ1 wilcox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95civ &raquo;</TD></TR><TR><TD CLASS="quote">yeah...i'm basically done with my turbo build, i just can't adjust my turbo to a good position for some reason with an internal wastegate. I've gotten advice to make the arm a little longer so the wastegate sits a little farther away from the turbo. It's just more of a hassle, if i could do it over again, i would've went with an external wastegate.</TD></TR></TABLE>
What turbo are you running?
Old Jul 12, 2005 | 01:04 PM
95civ's Avatar
T3 .42/.48, should i not have a problem with it? Just asking cause this is my first turbo build.
bsmith100
Nov 30, 2008 08:27 PM
gsr x civic
Apr 7, 2007 09:57 AM
Btothe3rdDegree
Mar 16, 2004 12:45 PM
Broken Gearbox
Jun 8, 2003 02:12 PM
TurbothisLS
Aug 29, 2002 07:27 PM
