No Fuel Pressure....what the hell is wrong?
Old Jul 11, 2005 | 05:13 AM
dEtSoOb's Avatar
Default No Fuel Pressure....what the hell is wrong?
got my car up and running yesterday and took it out for its maiden voyage to check and make sure everything was ok. Car was running great, everything seemed to be fine, but when I went to leave my buddy's house the car wouldn't start. I checked the fuel pressure gauge to find it reading 0. I checked the fuel pump fuse it is ok, i can hear the fuel pump turn on, and I don't have any leaks, but for some reason i have no fuel pressure. I checked the spark and it is fine so it has to be the fuel.
Anyone have a clue?!?!?!
Old Jul 11, 2005 | 05:20 AM
seen4ever's Avatar
Default Re: No Fuel Pressure....what the hell is wrong? (HKesque)
main relay maybe, fuel pump kicking on?
Old Jul 11, 2005 | 07:53 AM
B6tPoweredMx3's Avatar
Default Re: No Fuel Pressure....what the hell is wrong? (seen4ever)
Are you out of gas?
Old Jul 11, 2005 | 07:54 AM
beepy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">i can hear the fuel pump turn on</TD></TR></TABLE>
That negates the possibility of a bad fuse or relay.
If the fuel pump is pumping fuel but you are getting no pressure, there is only one possible culprit: Bad or improperly installed FPR.
Old Jul 11, 2005 | 08:24 AM
raene's Avatar
Default Re: No Fuel Pressure....what the hell is wrong? (beepy)
Also the pickup might've fallen off inside the tank...
Old Jul 11, 2005 | 08:39 AM
dEtSoOb's Avatar
how can i tell if the fpr went bad? that seems like it can be the only culprit left.
Old Jul 11, 2005 | 08:51 AM
Dunc's Avatar
BCICAN
Default Re: (HKesque)
Check the fuse box in the engine bay...check to make sure the fuse labeled ECU is good. The same thing happened to me when I was done street tuning, I guess it shorted out and I had no idea.
Old Jul 11, 2005 | 10:34 AM
raene's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HKesque &raquo;</TD></TR><TR><TD CLASS="quote">how can i tell if the fpr went bad? that seems like it can be the only culprit left.</TD></TR></TABLE>
Check if tons of fuel is pouring out of the return line - disconnect it from the rail and hold it into a bottle while someone primes the pump. It should go like a garden hose if fuel's making it to the line OK.
Old Jul 11, 2005 | 06:58 PM
dEtSoOb's Avatar
thanks for all the help guys, I pulled out the fuel pump and found the rubber hose running from the fuel pump was ruptured, so i replaced it and everything is all good again.
Old Jul 11, 2005 | 07:41 PM
Dunc's Avatar
BCICAN
good to hear
Old Jul 11, 2005 | 10:26 PM
raene's Avatar
That line should only be under neg. pressure, what caused it to rupture? Any ideas?
Old Jul 12, 2005 | 06:08 PM
dEtSoOb's Avatar
it looks like it was more of a vaccum hose than a fuel line hose...dunno what the deal w/ that was but oh well, turned the boost up to .9 bar today and I'm lovin every minute of it
crazygerman
Mar 4, 2006 11:57 AM
tegturbo
Aug 11, 2005 04:18 PM
SLOW4drINTEG
Jul 30, 2003 07:09 AM
Boostless97Lude
Dec 26, 2002 12:04 PM
Boostless97Lude
Dec 26, 2002 11:33 AM
