VAFC Hack throttle points setting?
Old Jul 11, 2005 | 01:32 AM
pramonn's Avatar
Default VAFC Hack throttle points setting?
Im going to boost my d16y8 stock internal this weekend.
set up as follow
450 DSM (blue top)+VAFC
Resistor box
OBD2 ECU
Stock fuel pump
IHI Rbh5 VJ20 @ 6psi
I read many post and article about VAFC hack (liam, Thermal, Home-made turbo, Turbo D16 etc. )
BUT I just cant find a good explanation <U>about setting throttle point</U>?
Normally for NA car the TH-point will be around 10%-50%
1.WHY when we turbo a car we need to move to 71%-72% or 91%-92%?
2.What will effect if we still set TH-point 10%-50% when turbo?
3.Is this TH-point change can cause any CEL?
Thanks in advance
Old Jul 11, 2005 | 02:07 AM
swlabhot's Avatar
Default Re: VAFC Hack throttle points setting? (pramonn)
The Throttle point tells the afc when to switch from the Low fuel settings/map to the Hi fuel settings/map at the % throttle position that you have set. Thats all it does.
2) There is no difference whether its NA or Turbo.
3) No, it does not affect your CEL in any way unless your fuel trims are way abnormal..
Old Jul 12, 2005 | 07:09 AM
pramonn's Avatar
Default Re: VAFC Hack throttle points setting? (swlabhot)
Oh ic.....thanks for tech. info
So if I set fuel map on LOW as same as on High
then it doesnt matter to set TH point at 10%-50% or 71%-72% right
an2ny888
Apr 14, 2005 09:01 AM
turb
Jun 20, 2003 04:30 AM
CPR
Oct 2, 2002 10:37 AM
SCsol
Apr 16, 2002 10:07 PM
