builder, sleeve or head gasket
Old Jul 9, 2005 | 06:50 PM
DrkGreenAccord's Avatar
Default builder, benson sleeve or head gasket
i got a h22 benson sleeve block stock bore. this is the third time that i have had water in the motor. the first time when the guy put the head on the block we couldnt get it out the driveway the oil was creamy, that was a cometic head gasket. the second time i put the head on my self, i couldnt even get it out the drive the oil was creamy. that was with a cometic head gasket. the third time didnt have a problem i drove it for a couple of month with no water in the motor then i pulled the head off, put it back on drove it for a couple of month and now a little bit of water in the motor. you cant see it on the dipstick, only when i pull the valve cover off underneath it its covered with that creamy ****. im loosing water the car is starting to run hot and on the distributor side there is a big oil leak between the head and block. i was just about to get it tuned.
the car is for sale 7000
95 coupe eg
benson block cp piston pauter rods
rev valve spring retainer
4 puck sprung clutch
sprint steering wheel
rota grid wheel gunmetal polish lip
sfp manifold and downpipe
f-max turbo, piping and intercooler
p28 hondata boost option
carbonfiber hood black roof and black tunk
Modified by DrkGreenAccord at 4:19 AM 7/10/2005
Old Jul 9, 2005 | 07:42 PM
11SECEG's Avatar
Default Re: builder, benson sleeve or head gasket (DrkGreenAccord)
have your head resurface...
Old Jul 9, 2005 | 09:44 PM
PrettyLude's Avatar
bring the head to a machine shop and have them check it for straightness, and use a oem headgasket
Old Jul 9, 2005 | 10:40 PM
i had the head resurfaced the last time i put it on
Old Jul 10, 2005 | 01:06 AM
Cloner's Avatar
There is only two mating surfaces the head and the block.You resurfaced the head.Now go and get the block decked cause something is not right with the block.I had the same problem a couple years ago exactly what happened to you happened to me.Also make sure your dowel pins or anything else are not sticking up to high.
shm91
Feb 14, 2014 08:58 PM
slipyoke
Jun 17, 2012 07:22 PM
scspeed
Apr 18, 2009 01:54 PM
SpoolnG2
Mar 7, 2004 08:17 PM
syndicate43
Oct 13, 2002 07:38 PM
