Cold engine idle problem. 3bar?
Old Jul 8, 2005 | 07:37 AM
EGP's Avatar
EGP
Default Cold engine idle problem. 3bar?
Hopefully this is something simple.
I have a 99 turbo Si, recently changed to OBD1 and 3bar map sensor. When I start the car in the morning, it idle's like ****, and if I give it gas it'll rev then die, also tip in thottle the car sputters. It'll keep acting like this until my engine warms up, then it idles and drives perfect.
I've checked the map sensor wiring like 20 times and completely redid the wires twice. If it's not the map sensor, what else could it be?
Thanks.
Old Jul 8, 2005 | 07:55 AM
11psiTurboSI's Avatar
Default Re: Cold engine idle problem. 3bar? (EGP)
What engine management are u using?
Old Jul 8, 2005 | 08:09 AM
EGP's Avatar
EGP
Default Re: Cold engine idle problem. 3bar? (11psiTurboSI)
Neptune
Old Jul 8, 2005 | 12:04 PM
EGP's Avatar
EGP
In case anyone does a search on the same thing.
I bleed the air out of my coolant system and it fixed the problem.
jdm95
Engine Management and Tuning
Feb 2, 2010 08:10 PM
Special B
Sep 13, 2007 12:52 PM
rschoener
May 3, 2002 03:02 AM
GQ 05YellowEVO8
Jul 12, 2001 09:23 AM
