boost help please
Old Jul 10, 2005 | 01:34 PM
wpgcivic's Avatar
Default boost help please
i finished my turbo kit on my civic and the first night we put a base map on the ecu took it out and was boosting about 9 psi on the internal wastegate for the 14b, next day i changed the oil, put in 2 stage colder plugs and richened the map up and now only hit like 4-5 psi and 5000 rpm and up i lose boost, any ideas?
ps: no leaks in the charge pipes or anything
Old Jul 10, 2005 | 09:16 PM
wpgcivic's Avatar
ttt
Old Jul 10, 2005 | 11:14 PM
TurboIntegraGSR's Avatar
Default Re: (wpgcivic)
Weird.... only thing I can think of is possibly electronics... go over everything make sure wiring is straight, re-check base timing, do you have a check engine light?, pull plugs, make sure plug wires are tight.
this weird kind of stuff just needs some figeting sometimes.
good luck
Old Jul 10, 2005 | 11:17 PM
Cloner's Avatar
Default Re: (TurboIntegraGSR)
Check your wastgate and lines to it.
Old Jul 11, 2005 | 06:08 AM
adseguy's Avatar
Default Re: (Cloner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cloner &raquo;</TD></TR><TR><TD CLASS="quote">Check your wastgate and lines to it.</TD></TR></TABLE>
for what? Really really good wastegate lines
possible boost leak at BOV or somehwere small. Has your vaccum at idle changed at all?
Old Jul 11, 2005 | 08:10 AM
wpgcivic's Avatar
nah vacuum is the same just above 20 psi, no cel's, i think what we are gonna do tonight is try another wastegate
Old Jul 11, 2005 | 09:03 AM
Blaze45's Avatar
Brrraaaap!
My buddies car with an open 02 housing and the 14b always would loose boost around 5k. Then he put a full exh. sysytem on and now it only fluctuates 1psi where it used to drop 4 or 5 psi. Its really gay, Ive herd other people have the same problem as well...
Old Jul 11, 2005 | 09:11 AM
wpgcivic's Avatar
all my o2 bungs are filled, maybe i have an exhaust leak somewhere
Old Jul 11, 2005 | 10:40 AM
adseguy's Avatar
post turbo leak: Not a problem (it's acutally good )
Pre turbo leak: loss of spool and boost depending on how bad it is.
If you want to check for a leak fill up a spray bottle with soapy water and start up a cool engine. Then spray liberally all over the exhaust gasket and fitting from manifold to turbo. If you see bubles, you have a leak.
Old Jul 13, 2005 | 04:14 AM
wpgcivic's Avatar
fixed, was wastegate, thanks for help
Old Jul 13, 2005 | 05:25 AM
adseguy's Avatar
what exactly was wrong with your wastegate?
Old Jul 13, 2005 | 06:35 AM
wpgcivic's Avatar
i guess the rod was bent or something because as soon as the new one was on, good to go
madracer
Sep 14, 2008 12:36 PM
zenon8890
Aug 18, 2006 04:07 PM
BoostedEgHatchFl
Aug 25, 2005 03:22 AM
91glassycrx
May 7, 2004 08:08 AM
crucial si
May 31, 2003 08:46 PM
