filter resticts boost/?
Old Jul 8, 2005 | 12:48 PM
ldanphanl's Avatar
Default filter resticts boost/?
can the filter that goes on the turbine effect the amount of boost you are capable of getting?, because my waste gate is set at 10 psi, but until red line i've only been able to take it to about 3-5 psis max. anyone any imput about this?
Old Jul 8, 2005 | 12:52 PM
YiNYaNg's Avatar
Default Re: filter resticts boost/? (ldanphanl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ldanphanl &raquo;</TD></TR><TR><TD CLASS="quote">can the filter that goes on the turbine effect the amount of boost you are capable of getting?, because my waste gate is set at 10 psi, but until red line i've only been able to take it to about 3-5 psis max. anyone any imput about this?</TD></TR></TABLE>
you got a boost leak
Old Jul 8, 2005 | 01:18 PM
EJ1 wilcox's Avatar
Default Re: filter resticts boost/? (H-T)
It depends on the filter setup...
When I first put my turbo on I put a screen and a piece of fleece over my turbo intake and it would only boost like 4-5psi... then I took the fleece off there and put a filter on and whoa! 8 psi and much better spool characteristics..
If the filter is really small, clogged, or poorly designed, it could choke the turbo and not allow it to boost to its potential.
Either that or you have a boost leak somewhere.
Old Jul 8, 2005 | 07:44 PM
ldanphanl's Avatar
nvm
thanks guys for you imput, it turs out that one of the bolts from the flange to the manifold fell out. nothing a couple of lock washes can't fix.. weeeee. thanks abunch guys.
i love honda-tech boosties!!
Old Jul 8, 2005 | 07:46 PM
NuclearB18B's Avatar
Default Re: filter resticts boost/? (EJ1 wilcox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox &raquo;</TD></TR><TR><TD CLASS="quote">It depends on the filter setup...
same exhact thing happened with me.
GAINZ
Nov 27, 2015 05:38 PM
CarterRace.com
Jul 13, 2007 02:52 PM
Boosted2K
Oct 20, 2004 07:39 PM
silverEH2
Mar 19, 2003 08:16 AM
