Pics of my Full-Race Turbo kit.
Hello guys
As some of you know, I had a Topic about me asking about the T3/T67
https://honda-tech.com/zerothread?id=1273803
Well I finaly got it !! I got a Full-Race turbo kit Stage3 AC
Here are some pics that my brother took
Thanks to Terry from Boostfed.com and all the guys from Full-Race
Hopefully next week I will post some pics of everything on the car
The setup is listed in the H-T garage , I have a link in my signiture
Thanks
Marlon
Modified by Marlon88 at 6:41 PM 9/4/2005
Thanks
Marlon
Re: (1995Ex_Sedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1995Ex_Sedan »</TD></TR><TR><TD CLASS="quote">How much does that run? Money wise?</TD></TR></TABLE>
"more than you can afford pal...full-race"
check out http://www.boostfed.com or http://www.full-race.com
And its "More than YOU CAN AFFORD pal"......haha sound so ricer quoting fast and furious.
Good song by the way: perfect circle-3 libras
Re: (Makdaddynuge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Makdaddynuge »</TD></TR><TR><TD CLASS="quote">check out http://www.boostfed.com or http://www.full-race.com
Good song by the way: perfect circle-3 libras</TD></TR></TABLE>
Or http://www.evans-tuning.com
Re: (1995Ex_Sedan)
It costed me alot because I live in Europe and I had to pay alot for shipping and I had to pay 25% on the total price Duty and Taxes in the Customs department
Thanks guys for your nice comments !! I can`t wait till I have everything put together !! For now I am going to run 8psi till I upgrade my stock ECU for an EMS.
I don`t think that it will be very good with that low PSI because of the turbo size
How do you think it will run with only 8psi ?! what WHP should I get with 8psi !?
Thanks
Marlon
Thanks
Marlon
Re: (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue »</TD></TR><TR><TD CLASS="quote">don't even put the kit on until you upgrade your stock ecu. </TD></TR></TABLE>
yeah dont even try the kit without a proper fuel management... or it could cost you even more...
Re: (yellowturbo)
I am going to run a Walbro 255lph HP in tank fuel pump , AEM fuel Rail and AEM fuel pressure regolator , Blox missing link and Vortech 12:1 FMU .
I don`t think that I will have problems with the fuel system with only 8 PSI because I have some friends running the same setup on Drag Turbo Kit with 8psi and they had no problems !!!
I was going to run this setup till after the summer , because then I am going to buy an Autronic EMS and some RC 750cc injectors .
Re: (Marlon88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marlon88 »</TD></TR><TR><TD CLASS="quote">I am going to run a Walbro 255lph HP in tank fuel pump , AEM fuel Rail and AEM fuel pressure regolator , Blox missing link and Vortech 12:1 FMU .
I was going to run this setup till after the summer , because then I am going to buy an Autronic EMS and some RC 750cc injectors .</TD></TR></TABLE>
marlon -- dont use an FMU!! this turbo kit moves so much air that the fmu cant possibly add enough fuel for it. This is a much larger turbo than your friends DRAG kit so you will deifnatley be running much leaner. At the very least, please use larger injectors with a chip and the FMU, while the ignition wont be right, at least there would be fuel...
please consider the risk you are taking as it could definatley destroy your engine
Re: (Marlon88)
my friend just blew his ringlands with a fmu setup on a drag kitted gsr motor. You will be making way more power than him so i would suggest something better
Re: (Marlon88)
Don't even put it on until you get these two things.
Re: (Full-Race Geoff)
If I buy a VAFC and some bigger injectors would I be Ok ?!
when I was going to finish my engine I was going to a dyno to see the Air/Fuel ratio !!
Re: (Marlon88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marlon88 »</TD></TR><TR><TD CLASS="quote">****
If I buy a VAFC and some bigger injectors would I be Ok ?!</TD></TR></TABLE>
no! You need some kind of real managment that adjusts timing and fuel.
nice towel! for some reason even a hot chic in a bakini is not as sexy as full race welds
dude you went to far for settling less then an EMS... just be patient and do it right the first time... it's either patience now, or learn patience when your waiting for your motor to get rebuilt
Location: We Cant Stop Here This Is Bat Country, So CaL, USDM
Re: (Marlon88)
like they said...don't do it till you have the complete fuel setup....you've spent so much so far don't throw it all away. If you get the urge to install everything early, just get super drunk so you can't stand up then you won't be tempted to install anything.
Re: (SOHC_MShue)
guess i have to change plans from after the summer to now
What injectors should I buy with this kit , 750cc or 1000cc ?
The goals are 500 whp.
Re: (Marlon88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marlon88 »</TD></TR><TR><TD CLASS="quote">guess i have to change plans from after the summer to now
The goals are 500 whp.</TD></TR></TABLE>
Get 1000cc injectors, I will hook you up Marlon. Also if you need Hondata or AEM EMS I can hook you up on that too!!! Also FAST or Accel DFI whichever sir. I owe you soooooo................
