master power turbo I brought
I brought this Master power turbo. can anyone tell me the HP range of this turbo http://redlineracer.org/estore...id=70
When should it spool up? is it a good turbo for the street? how much PSI is it good for?
Re: (Drag_On)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drag_On »</TD></TR><TR><TD CLASS="quote">Its a piece of ****. But a real turbo.</TD></TR></TABLE>
Okay....
There was just a thread about these turbos like yesterday and it was determined that the REAL master power turbos are good turbos, but the ones SSautoshit sells are not genuine and are in fact pieces of ****...
So, it looks like you have a real one, an it should work fine for you.
I would have to see the compressor map and know which engine you are running it on as well as the rev range to answer your questions.
Okay....
Re: (EJ1 wilcox)
link to that thread you seen yesterday ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox »</TD></TR><TR><TD CLASS="quote">
Okay....
Okay....
Re: (integlspwr2k)
I have personally run a master power T3/TO4E 57-trim on my other car (jy-ish D16y8, zex cam, drag mani, etc) and put over 25K miles on it with no issues. They are nothing like what SSautourine sells.
http://www.boostedsystems.com/
You can get those for 100 bucks cheaper than at redlineracer or whatever. That's where I ordered my turbo from.
Re: (integlspwr2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integlspwr2k »</TD></TR><TR><TD CLASS="quote">link to that thread you seen yesterday ?</TD></TR></TABLE>
Here you go:
https://honda-tech.com/zerothread?id=909985
Here you go:
Re: (EJ1 wilcox)
well turbo came yesterday. I just have to find a 4 bolt flange. the downpipe on the car is a 5 bolt so I have to pull the downpipe and have a new flange welded on. its a REAL Master power turbo made in brizal and has a serial number and stamp on the back of the housing. now here comes the hard part finding someoen in MD that has a 4 bolt flange and desiding if I should dyno the car with TEC2 engine management or install Genboard and dyno tune that.
i ♥ my honda
Global Mod
Global Mod
Re: (tyrone27)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tyrone27 »</TD></TR><TR><TD CLASS="quote">Genboard </TD></TR></TABLE>
http://www.vems-group.org/products.html
Any one have any more info on this EMS? Tyrone do you have experience with this? Iv never heard of it being used on a Honda. I am guessing that it requires a full re-wire.
Re: (dustin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White Smoke »</TD></TR><TR><TD CLASS="quote">
yea its works on honda, I know most of the people on the developement team. They are very smart and dont cut corners in there engineering.
Nick
Nick
