what is this for
Old Jul 9, 2005 | 12:28 AM
Rubixcu7's Avatar
Default what is this for
im putting in my turbo tomorrow and i am not sure what the hole in the middle is for. its a garret t25
Old Jul 9, 2005 | 02:11 AM
Danger's Avatar
Default Re: what is this for (Rubixcu7)
i believe that would be for the coolant line , is there another hole on the opposite side ?
Old Jul 9, 2005 | 02:15 AM
Quad-Damag's Avatar
it's for hooking up the water cooling option for that turbo
some people run it, others don't.
Old Jul 9, 2005 | 06:25 AM
2000BoostedEX's Avatar
Default Re: what is this for (Quad-Damage)
definately the coolant hole!!
Old Jul 9, 2005 | 10:46 AM
Rubixcu7's Avatar
so i should just block it?
Old Jul 9, 2005 | 10:48 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: (Rubixcu7)
no, run the coolant lines. its not hard and costs like 5 bucks to do
Old Jul 9, 2005 | 12:03 PM
Haberdasher's Avatar
If you don't use it it does not need to be plugged. There are no moving parts exposed inside the water jacket.
Old Jul 9, 2005 | 01:42 PM
TunerToys's Avatar
I agree with everyone who said "coolant" connections. In addition, most T25s use 14mm boss (parallel threads) fittings for those connections.
And it is easy to do, just pick off the coolant line between the manifold and TB.
Hope that helps!
Old Jul 9, 2005 | 06:16 PM
Rubixcu7's Avatar
where would it come out? there is only those 3 openings and i know the other 2 are for the oil, one feed and one return
Old Jul 9, 2005 | 06:18 PM
wantboost's Avatar
Who is Mr Robot?
um, there should be 4. look on the other side
Old Jul 11, 2005 | 08:27 PM
TunerToys's Avatar
Default Re: (wantboost)
Here is an image of the connections we use on the T25. Our upcoming connection kits will use all AN connections, but you can use whatever works for you. I just included the picture so you could see the relation of all the connections. The top and smallest is oil IN, the largest and bottom is oil OUT. The two side connections are water IN/OUT.
Hope that helps.
Craig
powerdbygarrett
Mar 13, 2009 10:53 AM
hondapimpin420
May 17, 2007 09:41 AM
done
Oct 14, 2005 12:24 PM
hatchracer02
Jan 24, 2005 08:14 AM
BoostedD15B7
Jan 29, 2003 12:01 AM
