help with csr with greddy turbo??SMOG??
help with GSR with greddy turbo??SMOG??
Hope some one can help!!!
I have a 94 cx hatch with a 95 gsr swap which has been reffed. I then installed the GREDDY turbo and can't pass smog becuase the o2/ecu sees more air and sends more fuel(its reading rich on the tester) What's the most inexpesive way to drop the boost to 0psi without installing boost control and will this fix the problem with the fuel? One more question is can you get the turbo reffed on top with the engines reff?
