Still stuck on which FPR and why.
Old Aug 4, 2005 | 09:49 AM
jDMJeRk's Avatar
Default Still stuck on which FPR and why.
I need a FPR, but I don't know what one to get. My car has a RevHard IM and a AEM fuel rail, but Im un sure on what exactly I need to mount a specific fpr to my AEM rail, and which ones will actually fit due to my IM. As well, what extra fittings Ill need (if any at all) to make specific fprs work with my existing OEM equipment.
Here is a rundown on what I've read:
b&m... Not a real 1:1 not a good idea
AEM... has "exploded" on people
aeromotive... seems to be the way to go, but Id have to buy more fittings and lines (maybe be over board with my whp goal)
Im shooting for around 400-500whp on about 18psi on a t3/t4 with 880's or less.
What do you guys think?
TIA!
n!ck
Old Aug 4, 2005 | 09:54 AM
tgreaves's Avatar
Default Re: Still stuck on which FPR and why. (jDMJeRk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jDMJeRk &raquo;</TD></TR><TR><TD CLASS="quote">I need a FPR, but I don't know what one to get. My car has a RevHard IM and a AEM fuel rail, but Im un sure on what exactly I need to mount a specific fpr to my AEM rail, and which ones will actually fit due to my IM. As well, what extra fittings Ill need (if any at all) to make specific fprs work with my existing OEM equipment.
TIA!
n!ck</TD></TR></TABLE>
????? A little overboard with your power goals, 400-500whp huh.. And Im not sure about the 880's with that hp level.. I would get the aeromotive, with all the money you spent its not much more for all the fitting and a really nice setup..
Old Aug 4, 2005 | 10:02 AM
jDMJeRk's Avatar
Default Re: Still stuck on which FPR and why. (tgreaves)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">????? A little overboard with your power goals, 400-500whp huh.. </TD></TR></TABLE>
Its just a b16 built top to bottom. Ive seen it done. Assuming I hit 400whp; I'd be happy. Any more is just extra.
Again though with my luck, Ill only hit 340whp or so... Well just have to see... Im still thinking Aeromotive myself.... but I know there is someone out there with the same power as me that was a penny pincher that has made something work (And yes I know you get what you pay for!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">880's at that whp level... </TD></TR></TABLE>
You think I need 1000cc? I heard it would be harder to tune possibly... I dunno Im so confused on what to get with so much hear say and actual knowledge and experience. RC's site has a calculator and they said I needed like 660's for 400whp.... I thought it was BS. m3h=confused. :sigh:
n!ck
Old Aug 4, 2005 | 10:03 AM
tgreaves's Avatar
Again though with my luck, Ill only hit 340whp or so... Well just have to see... Im still thinking Aeromotive myself.... but I know there is someone out there with the same power goals as me that is a penny pincher that has made something work (And yes I know you get what you pay for!)
Most people would think that an Aeromotive would be overkill for 200-250whp.. Make me laugh when you said overkill for 400-500whp..
Get the Aeromotive, its not worth messing with anything else when you can get the best..
Old Aug 4, 2005 | 10:10 AM
seen4ever's Avatar
I'll sell you my bused Paxton FPR i bought 2 yrs ago for $200+, that now just holds a constant fuel pressure rather than raising it or lowering it.
i replaced it with a Aeromotive, just some insite.
Old Aug 4, 2005 | 11:26 AM
Sprockets's Avatar
Why not get an Aeromotive that uses the stock fuel rail?
http://216.242.145.16/products/product.phtml?p=67
Old Aug 4, 2005 | 11:29 AM
tgreaves's Avatar
Default Re: Still stuck on which FPR and why. (USE2B16A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USE2B16A &raquo;</TD></TR><TR><TD CLASS="quote">Why not get an Aeromotive that uses the stock fuel rail?
I am thinking of doing this but I wonder about the amount of flow that the stock fpr opening can do.. Is it enough for a high volume fuel pump?
Old Aug 4, 2005 | 11:31 AM
NightRiderS2K's Avatar
In-N-Out Burger
Don't skimp on fuel related parts for your car. You have invested so much money into it and you wouldn't want it to get fucked up now because your FPR and its spring somehow broke causing your fuel pressure to go tooooooooo high----bye motor.
I like the aeromotive pictured above. Get that one
Old Aug 4, 2005 | 11:40 AM
rhd's Avatar
rhd
you can get one of terry's FPR's for a great price
Old Aug 4, 2005 | 11:51 AM
Sprockets's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">I am thinking of doing this but I wonder about the amount of flow that the stock fpr opening can do.. Is it enough for a high volume fuel pump?</TD></TR></TABLE>
They say..."Perfect for use with a stock fuel pump yet flows enough to handle big pumps like the Aeromotive A1000"
I use it with a Walbro 255lph HP.
Old Aug 4, 2005 | 12:11 PM
tgreaves's Avatar
I use it with a Walbro 255lph HP.</TD></TR></TABLE>
True.. It just make me wonder when looking at the small opening of the stock fpr hole..
Old Aug 4, 2005 | 12:48 PM
jDMJeRk's Avatar
The above fpr looks great.. but I have an AEM rail... Should I switch back to my stock rail with bigger injectors and a 255lph?
Old Aug 4, 2005 | 12:49 PM
jDMJeRk's Avatar
Default Re: (rhd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rhd &raquo;</TD></TR><TR><TD CLASS="quote">you can get one of terry's FPR's for a great price</TD></TR></TABLE>
wtf is that? link? vouches?
Old Aug 4, 2005 | 12:53 PM
jDMJeRk's Avatar
Default Re: (jDMJeRk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jDMJeRk &raquo;</TD></TR><TR><TD CLASS="quote">The above fpr looks great.. but I have an AEM rail... Should I switch back to my stock rail with bigger injectors and a 255lph?</TD></TR></TABLE>
lol I was just thinking... If my AEM rail uses my STOCK FPR now and stock lines and that aeromotive one uses a stock rail... then everything should work on the aem rail then lol right?
What about clearance issues with my Revhard intake manifold?
Old Aug 4, 2005 | 01:09 PM
wantboost's Avatar
Who is Mr Robot?
im using an aeromotive fpr with my aeromotive pump
Old Aug 4, 2005 | 01:17 PM
ME=ADRIAN's Avatar
Default Re: (wantboost)
anyone using sx?
Old Aug 4, 2005 | 01:21 PM
rhd's Avatar
rhd
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jDMJeRk &raquo;</TD></TR><TR><TD CLASS="quote">wtf is that? link? vouches?</TD></TR></TABLE>
boostfed on here
Old Aug 4, 2005 | 01:29 PM
DaveF's Avatar
What about clearance issues with my Revhard intake manifold?</TD></TR></TABLE>
you might need to get one of those adapters made by jackson racing, to "rotate" your fpr so it doesnt hit the plenum.
Old Aug 4, 2005 | 02:10 PM
hulkhb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jDMJeRk &raquo;</TD></TR><TR><TD CLASS="quote">What do you guys think?
Why you worried about it that much anyway, you know your gona blow it up the first day anyway , lol. get it done man!
Old Aug 4, 2005 | 02:13 PM
jDMJeRk's Avatar
Default Re: Still stuck on which FPR and why. (hulkhb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hulkhb &raquo;</TD></TR><TR><TD CLASS="quote">Why you worried about it that much anyway, you know your gona blow it up the first day anyway , lol. get it done man! </TD></TR></TABLE>
Im trying to get it done you bitch lol.... I need hella parts still... I just hope I make BOTI. My manifold isnt even started yet!
Anyhow.... Im thinking that 11316 is the one to get... the 15 is for a sohc vtec right?
And I probably blow it up on the dyno duh!
Old Aug 4, 2005 | 04:50 PM
boostedcivicsir's Avatar
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">Get the Aeromotive, its not worth messing with anything else when you can get the best..</TD></TR></TABLE>
from me on the aeromotive, the paxton reg is a good one too.
Old Aug 5, 2005 | 01:18 AM
JDMorgan's Avatar
holla
trecool44
Oct 8, 2014 06:55 PM
Topdawgg
Dec 21, 2006 12:26 AM
w0ng_sta
Oct 6, 2006 09:18 AM
LSTEG96
Oct 30, 2003 08:18 PM
CM-R
Feb 9, 2002 02:07 AM
